2.7 Six conversion questions, Oil cooler and motronic |
bigkensteele |
Feb 26 2015, 10:19 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Topic 1: Has anyone ever tried mounting an oil cooler under a GT lid just above the fan, and if so does it keep the temp low enough for DE events?
Topic 2: Has anyone here ever adapted motronic from a 3.2 to work on a 2.7? If so, what is involved? Which distributor? What cam? Stock low compression CIS pistons or JEs? Topic 3: What kind of power can I get if I keep the CIS but am willing to port the heads, change cams and go to JE pistons? Please feel free to address any or all of the above? I have a '74 2.7 core that is currently torn apart and ready to send out for machining. It already has case-savers and nikasil jugs, so I am going to stay at 2.7. I have all of the CIS parts, so that is an option for induction, but I would rather do something else (other than carbs). I will also be running stock 6 heat exchangers and a 911 muffler. I just can't bear the thought of rebuilding this thing and only ending up with 150 hp, so any tips would be most appreciated. |
Steve |
Feb 27 2015, 01:46 PM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
A 2.7 runs a lot hotter than an aluminum 3.0 or 3.2. I would go with a front cooler or under the rear trunk with a fan and grill to protect the cooler from rocks.
bigkensteele |
Feb 27 2015, 10:40 PM
A 2.7 runs a lot hotter than an aluminum 3.0 or 3.2. I would go with a front cooler or under the rear trunk with a fan and grill to protect the cooler from rocks. I will not (nor could I) run the thermo reactors used on the 75 - 76 911 motors. The core that I have is a 74 with an 11 blade fan. I will be running either headers or six exhchangers. I am not a metallurgist, but I cannot fathom how the single variable of case material (mag. vs. alum.) could account for any significant increase in thermo-retention, especially when compared to a larger displacement motor. Not trying to be contentious, but I need to understand how an otherwise equal engine would run hot just because it was a mag. case 2.7 vs. a alum. case 3.0 or 3.2. Thanks to all for the input. |
Lo-Fi Version | Time is now: 17th May 2024 - 12:31 AM |
