2.7 Six conversion questions, Oil cooler and motronic |
bigkensteele |
Feb 26 2015, 10:19 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Topic 1: Has anyone ever tried mounting an oil cooler under a GT lid just above the fan, and if so does it keep the temp low enough for DE events?
Topic 2: Has anyone here ever adapted motronic from a 3.2 to work on a 2.7? If so, what is involved? Which distributor? What cam? Stock low compression CIS pistons or JEs? Topic 3: What kind of power can I get if I keep the CIS but am willing to port the heads, change cams and go to JE pistons? Please feel free to address any or all of the above? I have a '74 2.7 core that is currently torn apart and ready to send out for machining. It already has case-savers and nikasil jugs, so I am going to stay at 2.7. I have all of the CIS parts, so that is an option for induction, but I would rather do something else (other than carbs). I will also be running stock 6 heat exchangers and a 911 muffler. I just can't bear the thought of rebuilding this thing and only ending up with 150 hp, so any tips would be most appreciated. |
SirAndy |
Feb 28 2015, 06:38 PM
Resident German Group: Admin Posts: 41,640 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
does it keep the temp low enough for DE events? Here are your two choices: - Install a front mounted cooler now. - Fiddle with other solutions, spent time and money only to find they don't work well, then install a front mounted cooler anyways. (IMG:style_emoticons/default/popcorn[1].gif) |
bigkensteele |
Feb 28 2015, 07:04 PM
Here are your two choices: - Install a front mounted cooler now. - Fiddle with other solutions, spent time and money only to find they don't work well, then install a front mounted cooler anyways. (IMG:style_emoticons/default/popcorn[1].gif) OK, I get it already. And that leads to my next question. Has anyone here ever done a trombone style in the fender well? |
mepstein |
Feb 28 2015, 07:07 PM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Here are your two choices: - Install a front mounted cooler now. - Fiddle with other solutions, spent time and money only to find they don't work well, then install a front mounted cooler anyways. (IMG:style_emoticons/default/popcorn[1].gif) OK, I get it already. And that leads to my next question. Has anyone here ever done a trombone style in the fender well? 914 fenders do not get pass through air like a 911. Lots of threads on different oil cooler locations but like Andy said, the front is the most effective. It's just a pain in the wallet to get it there. |
bigkensteele |
Feb 28 2015, 07:42 PM
914 fenders do not get pass through air like a 911. Lots of threads on different oil cooler locations but like Andy said, the front is the most effective. It's just a pain in the wallet to get it there. Problem is that I want to run an LE dam and I don't want to cut my bumper, so getting air into it is the issue. I am not running fog lights currently. I wonder if enough air enters the grills to be effective? It's gotta go somewhere, right? (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:32 AM |
