WTB: M10x1.0 Time Sert Kit, Update - CHT Repaired. I'm done with it and will loan it out if anyone needs it. |
BeatNavy |
Feb 28 2015, 08:35 AM
2.0L engine I have has the original CHT spot stripped, so PO tapped a spot near the #4 intake runner based on the Capn's advice which presumably works just fine. While I have the engine out, however, I'm interested in repairing the original CHT location. I see it takes an M10x1.0. Anyone out there go through this process and want to unload (or loan (IMG:style_emoticons/default/smile.gif) ) their kit they don't need anymore? I see they are available for $90 on Ebay, but I'm feeling like a cheap-ass right now with all the other money I've spent on projects recently. Thanks!
BeatNavy |
Mar 15 2015, 09:51 AM
I ended up getting the Time Sert Kit. The M10x1.0 inserts come in depths of 6.2, 8, 9, and 15mm. The 15mm is too long, as the total depth of the CHT hole seems to be between 15mm and 20mm and you're supposed to leave a 6mm allowance beyond the insert. So I ended up going with the 9.0mm insert (which, of course, had to be purchased separately from the inserts that came with the kit).
Anyway, the repair seemed to have worked well. I am now special as I have two CHT's (IMG:style_emoticons/default/piratenanner.gif) If anyone needs to borrow this I'll gladly make it available so you don't have to spend $90 for a one-time use. I have one extra 9mm insert but after that you have to spring for the $2.00 and buy your own (IMG:style_emoticons/default/smile.gif) Threads Stripped Kit and inserts Hole prepped and ready for insert CHT Installed Two CHT's! Best enhancement ever. Maybe. |
Lo-Fi Version | Time is now: 9th May 2024 - 07:28 AM |
