Sand blasting advice |
ggenovez |
Mar 3 2015, 11:36 AM
Newbie Group: Members Posts: 19 Joined: 8-December 14 From: DFW Member No.: 18,201 Region Association: None |
Hi all,
I'm looking for some sand blasting advice. What media do you recommend, and how can I avoid warppage? What do you recommend to coat the sandblasted metal with? I purchased a 20lbs HF sand blaster and I'm planning on doing this myself |
Mar 3 2015, 11:57 AM
914-6 GT in waiting Group: Members Posts: 19,220 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Make sure you wear proper respirator.
Mueller |
Mar 3 2015, 12:08 PM
Make sure you wear proper respirator. ^this http://www.tractorsupply.com/en/store/blac...ing-media-50-lb Keep away from glass and trim (I have an HF soda blaster that will not harm glass) |
screenguy914 |
Mar 3 2015, 01:32 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Don't use sand or other hard material on body panels. It will warp and/or work-harden the sheet metal. Soda is a better blast media.
Blast media of any type will infiltrate every nook and cranny in your car. There are better, more gentler ways to remove paint - like paint stripper. Sherwood PS: for generic automotive questions like this, I'd source a broader source of information, like a body and paint forum. MHO. |
Cairo94507 |
Mar 3 2015, 02:54 PM
Michael Group: Members Posts: 9,703 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I would use soda to blast the body panels and sand for the floors and undercarriage. Sand could tend to warp body panels. With sand be prepared for a big mess.
Evil Older Brother |
Mar 3 2015, 03:10 PM
Member Group: Members Posts: 102 Joined: 9-September 13 From: Whidbey Island Member No.: 16,367 Region Association: Pacific Northwest |
Make sure you wear proper respirator. ^this http://www.tractorsupply.com/en/store/blac...ing-media-50-lb Keep away from glass and trim (I have an HF soda blaster that will not harm glass) And a condom. Be safe out there. |
DavidSweden |
Mar 3 2015, 03:28 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
From my own experience sand suks. I used aluminum silicate with a tarp under to collect the grit for reuse. You will need a good compressor, vary the pressure to avoid damage to the panels.
If you have some spare dollars use a professional shop that media blast with plastic beads which are far more gentle on panels, the shop can also spray primer directly onto the freshly blasted metal to stop oxidation. Soda (I have tried it) requires higher pressure and you will be surrounded in a thick fog of powder. For best results dry ice is excellent, I looked into when I renovated my 912 but is was too many $ |
altitude411 |
Mar 3 2015, 03:32 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/agree.gif) Plastic bead is the ticket...
ggenovez |
Mar 3 2015, 05:49 PM
Any source for plastic media? Amazon has some at $50 for 10 lbs. Sounds pricy. What about the bare metal. Anything I can do to prevent rust? |
luskesq |
Mar 3 2015, 06:33 PM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
I mostly use glass beads which can be had at HF at a decent price (remember coupon--they carry other media as well). I've discovered that it is a slow process when trying to remove the original paint (parts mostly) so a more agressive media would be better for larger areas. Hope you have a compressor with a decent CFM output or you will be frustrated.
Have fun, Keith |
altitude411 |
Mar 3 2015, 06:43 PM
Plastic is more expensive than other media but it can be reused/recycled many times... try these guy's http://compomat.com/acrylic-plastic-blast-media/
* rusting? primer & paint (IMG:style_emoticons/default/biggrin.gif) |
FourBlades |
Mar 3 2015, 07:38 PM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
Use a good moisture separator or your blaster will clog up with clumps of media every 15 minutes. Very annoying. Put a fan blowing on your compressor to help with cooling if you are going to blast for more than 30 minutes a day.
John |
Mar 3 2015, 07:50 PM
Resident German Group: Admin Posts: 41,602 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
sand blasting advice Don't ... http://www.914world.com/bbs2/index.php?sho...4700&st=120 (IMG:style_emoticons/default/headbang.gif) |
gandalf_025 |
Mar 4 2015, 02:26 PM
Senior Member Group: Members Posts: 1,447 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
The shop I sent my car to had it soda blasted and this is what it looked like when it came back to them.
They swear by this method. FWIW I have had cars sand blasted before. The finish was far rougher and there was sand everywhere forever.. |
Lo-Fi Version | Time is now: 19th April 2024 - 04:46 AM |
