Sand blasting advice |
ggenovez |
Mar 3 2015, 11:36 AM
Newbie Group: Members Posts: 19 Joined: 8-December 14 From: DFW Member No.: 18,201 Region Association: None |
Hi all,
I'm looking for some sand blasting advice. What media do you recommend, and how can I avoid warppage? What do you recommend to coat the sandblasted metal with? I purchased a 20lbs HF sand blaster and I'm planning on doing this myself |
mepstein |
Mar 3 2015, 11:57 AM
914-6 GT in waiting Group: Members Posts: 19,271 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Make sure you wear proper respirator.
Mueller |
Mar 3 2015, 12:08 PM
Make sure you wear proper respirator. ^this http://www.tractorsupply.com/en/store/blac...ing-media-50-lb Keep away from glass and trim (I have an HF soda blaster that will not harm glass) |
Evil Older Brother |
Mar 3 2015, 03:10 PM
Member Group: Members Posts: 102 Joined: 9-September 13 From: Whidbey Island Member No.: 16,367 Region Association: Pacific Northwest |
Make sure you wear proper respirator. ^this http://www.tractorsupply.com/en/store/blac...ing-media-50-lb Keep away from glass and trim (I have an HF soda blaster that will not harm glass) And a condom. Be safe out there. |
DavidSweden |
Mar 3 2015, 03:28 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
From my own experience sand suks. I used aluminum silicate with a tarp under to collect the grit for reuse. You will need a good compressor, vary the pressure to avoid damage to the panels.
If you have some spare dollars use a professional shop that media blast with plastic beads which are far more gentle on panels, the shop can also spray primer directly onto the freshly blasted metal to stop oxidation. Soda (I have tried it) requires higher pressure and you will be surrounded in a thick fog of powder. For best results dry ice is excellent, I looked into when I renovated my 912 but is was too many $ |
Lo-Fi Version | Time is now: 15th May 2024 - 12:41 PM |
