Rear Alignment shims |
maddog |
Mar 13 2015, 11:14 AM
Member Group: Members Posts: 200 Joined: 19-May 03 From: Grand Rapids Michigan Member No.: 710 Region Association: None |
Have you noticed uneven tire wear on your rear tires? Have your rear springs sagged or are the rear swing arms twisted? If you answered yes to any of the above questions, then your rear end needs an alignment. Eliminate the negative camber with the proper size shims, each mm of shim reduces negative camber by 10 minutes. These shims are NLA from the oem. They are laser cut from mild steel and sold in a kit of 3 (1 each of 2mm, 3mm, and 4mm sizes). The 2mm replaces 91433153303; 3mm replaces 91433153304; and 4mm replaces 91433153305. Be aware that you may need longer bolts if you increase the shim pack too much, standard bolt length is 55mm and longer bolts are 70mm. 1 kit is $29 + $5 shipping for any qty individual shims can be purchase for $8.50, $9.50 or $11 for 2,3 or 4mm
maddog |
Mar 12 2018, 05:52 AM
bump! check out my website for other parts that I sell for the 914
Mblizzard |
Mar 12 2018, 01:05 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Lets see I have the shims, rear sway bar mounts, front sway bar mounts, and hell hole repair kit.
All of these have been top notch items. Got my eye on the 914 DEAD PEDAL and Carbon Fiber Dash Panel Kit. |
914-300Hemi |
May 3 2018, 08:58 PM
Senior Member Group: Members Posts: 1,356 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California |
Is the web site still active?
maddog |
Jun 7 2019, 09:20 AM
Lo-Fi Version | Time is now: 8th May 2024 - 06:46 AM |
