Fuse Keeps Blowing- advice? |
mikedsilva |
Mar 15 2015, 05:38 AM
Member Group: Members Posts: 90 Joined: 23-February 15 From: Australia Member No.: 18,462 Region Association: Australia and New Zealand |
My new to me, 1970 914/4, has some iffy electrics..
The fuse in the number 7 spot, keeps blowing as soon as I turn the key to ignition on. So, this means I dont have any indicators or wipers working.. etc. Electrics are a little mysterious to me to be honest.. I do have a multimeter.. but I am not sure how to track this problem. I'm thinking I have a short somewhere on one of those systems.. Should I start by trying to unplug each and every component that uses that circuit, then reinstall another fuse, and turn the ignition on? How would an experienced auto electrician pinpoint a problem like this? Any and all advice appreciated.. Cheers Mike. |
BeatNavy |
Mar 15 2015, 06:31 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I'm certainly no master electrician either but it definitely sounds like you do have a short. Are you sure it's fuse 7? On the '71 Wiring Diagram it shows that that is only part of the license plate light circuit (through the main light switch).
Here's a link you'll need: Wiring Diagrams. Take your time and study this a little. It's hard to see, so you may have to zoom in with your browser when tracing the circuits. You're on the right track with your suggestions. Confirm which fuse and then use these diagrams for your model year to see what's on that circuit or could come into contact with that circuit through something like the main light switch. Remove the license plate light bulbs and see if you're still blowing the fuse. Inspect for spots where wiring insulation may have frayed through and is touching chassis. Let us know what you find. |
Lo-Fi Version | Time is now: 18th May 2024 - 11:34 AM |
