D-Jet Issues-getting close, Need a little more specific advice |
OU8AVW |
Mar 16 2015, 09:17 AM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
So I got my car back from the local Porsche shop and installed a rebuilt MPS from Bowlsby but the car is still not running right. Flat spots and intermittent dead fire misses. She starts right up, idles well and drives ok but when you get on it it has intermittent flat spots and when shes just cruising it misses once and a while. Seems like the advance is not ramping up like it should. Also, the mechanic left a vacuum line off the distributor. The line from the inboard connection on the pot is hooked up but the outside one is off. I understand that one of these is advance and one is retard.
Just need a list of crap to check (IMG:style_emoticons/default/biggrin.gif) |
DRPHIL914 |
Mar 16 2015, 11:07 AM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
TPS -
mine did the same thing and i always thought it was something else but since i swapped out a new TPS assembly i got from Bruce Stone, it now accelerates smoothly with no bucking or intermittant hickup like you are describing- none, 0, zilch! i can say, like new. and i had tried a replacement board but i still had an issue until the one went in. Unfortunately - i am no fighting a different d-jet issue... (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 01:14 PM |
