D-Jet Issues-getting close, Need a little more specific advice |
OU8AVW |
Mar 16 2015, 09:17 AM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
So I got my car back from the local Porsche shop and installed a rebuilt MPS from Bowlsby but the car is still not running right. Flat spots and intermittent dead fire misses. She starts right up, idles well and drives ok but when you get on it it has intermittent flat spots and when shes just cruising it misses once and a while. Seems like the advance is not ramping up like it should. Also, the mechanic left a vacuum line off the distributor. The line from the inboard connection on the pot is hooked up but the outside one is off. I understand that one of these is advance and one is retard.
Just need a list of crap to check (IMG:style_emoticons/default/biggrin.gif) |
OU8AVW |
Apr 23 2015, 07:41 AM
So now she's running pretty sweet. I am hiving a high idle issue. It idles at around 1600 rpm. It feels like the adjustment screw on the intake is mostly all the way in and I get no change from turning the adjuster on the computer. I checked for vacuum leaks with map gas but found nothing. I'm going to fiddle with the TPS some more.
Any other ideas? Maybe check the timing again? Maybe the advance is sticky? (IMG:style_emoticons/default/blink.gif) |
DRPHIL914 |
Apr 23 2015, 09:35 AM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
So now she's running pretty sweet. I am hiving a high idle issue. It idles at around 1600 rpm. It feels like the adjustment screw on the intake is mostly all the way in and I get no change from turning the adjuster on the computer. I checked for vacuum leaks with map gas but found nothing. I'm going to fiddle with the TPS some more. Any other ideas? Maybe check the timing again? Maybe the advance is sticky? (IMG:style_emoticons/default/blink.gif) this could be the alignment of your TPS still. - i ialso had the bucking issue for 5 years but once i got my repalcement TPS from Bruce stone its been like perfect ever since- except at first it was idling a bit fast, but that was cured by making 2 adjustments; one was the TPS, the other was the MPS was set too lean so making just a bit more rich helped, then reset the timing as well, and i cheated a bit here, and backed off the timing a few degrees and took it from 1000 rpm to 850 and has run perfect since! good luck |
Lo-Fi Version | Time is now: 21st May 2024 - 09:41 AM |
