D-Jet Issues-getting close, Need a little more specific advice |
OU8AVW |
Mar 16 2015, 09:17 AM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
So I got my car back from the local Porsche shop and installed a rebuilt MPS from Bowlsby but the car is still not running right. Flat spots and intermittent dead fire misses. She starts right up, idles well and drives ok but when you get on it it has intermittent flat spots and when shes just cruising it misses once and a while. Seems like the advance is not ramping up like it should. Also, the mechanic left a vacuum line off the distributor. The line from the inboard connection on the pot is hooked up but the outside one is off. I understand that one of these is advance and one is retard.
Just need a list of crap to check (IMG:style_emoticons/default/biggrin.gif) |
r_towle |
Apr 24 2015, 02:22 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If you cannot significantly change the idle with the air bypass screw, and almost make it die by turning it all the way in, you still have a vacuum leak.
Sources of leaks. Head----intake manifolds injector seals intake runners to plenum (large rubber hoses) anything plugged into the plenum and all rubber vacuum lines (cracks) Throttle body gasket Cold start injector gasket and injector itself I figure there are more I forgot, but I take a VERY methodical approach to finding the leak....remove all (except the MPS) If idle can now be controlled, one of those systems you removed is at fault. If idle cannot be controlled, check intake from plenum to head. Think of it this way. If I put 10 holes in your house, all over the place, 1 foot square each in size....you would have a 10 square foot leak in your house. Same thing applies here....lots of small leaks add up to a big leak. Rich |
Lo-Fi Version | Time is now: 21st May 2024 - 04:15 AM |
