D-Jet Issues-getting close, Need a little more specific advice |
OU8AVW |
Mar 16 2015, 09:17 AM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
So I got my car back from the local Porsche shop and installed a rebuilt MPS from Bowlsby but the car is still not running right. Flat spots and intermittent dead fire misses. She starts right up, idles well and drives ok but when you get on it it has intermittent flat spots and when shes just cruising it misses once and a while. Seems like the advance is not ramping up like it should. Also, the mechanic left a vacuum line off the distributor. The line from the inboard connection on the pot is hooked up but the outside one is off. I understand that one of these is advance and one is retard.
Just need a list of crap to check (IMG:style_emoticons/default/biggrin.gif) |
BeatNavy |
Jun 10 2015, 01:20 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Mike - I feel like we're having very similar issues with the 2056. Right now on hard decel/overrun I occasionally get the RPM's to drop where the engine will sometimes actually stall. It's very intermittent, which makes it weirder for me. It's no big deal (I just pop the clutch and engine fires back up), but a little disconcerting.
Did you see the thread today about fuel pressure? I'm going to try cranking mine up a notch or two (to 31 psi) as suggested on there. I guess dialing these in to perfect (or good) tune takes some experimenting and time... Good luck man. |
Lo-Fi Version | Time is now: 21st May 2024 - 05:12 PM |
