D-Jet Issues-getting close, Need a little more specific advice |
OU8AVW |
Mar 16 2015, 09:17 AM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
So I got my car back from the local Porsche shop and installed a rebuilt MPS from Bowlsby but the car is still not running right. Flat spots and intermittent dead fire misses. She starts right up, idles well and drives ok but when you get on it it has intermittent flat spots and when shes just cruising it misses once and a while. Seems like the advance is not ramping up like it should. Also, the mechanic left a vacuum line off the distributor. The line from the inboard connection on the pot is hooked up but the outside one is off. I understand that one of these is advance and one is retard.
Just need a list of crap to check (IMG:style_emoticons/default/biggrin.gif) |
OU8AVW |
Aug 28 2015, 12:22 PM
After my last adjustment that's about where I am too. Tendency to stall is less now. I saw an adjustment procedure for the decel valve. I'll try that later. 16-17 does seem lean. I'm not finding any consensus on the net about these numbers.
914_teener |
Aug 28 2015, 12:35 PM
914 Guru Group: Members Posts: 5,199 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
After my last adjustment that's about where I am too. Tendency to stall is less now. I saw an adjustment procedure for the decel valve. I'll try that later. 16-17 does seem lean. I'm not finding any consensus on the net about these numbers. A bad decel valve can cause similar problems at idle and stalling. Make sure it is working correctly and not leaking first before you adjust it. You've done a great job learning the system and doing it yourself. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 08:22 PM |
