electrical issues, starter, lights |
rhodyguy |
Jun 4 2003, 06:44 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
tried a crank over yest. nothing. the car came with a hot start relay. i disconnected it and ran the wires normaly. still nothing. shorted the two large soleniod terminals as per the lash book. starter spins, no solenoid engagement. is there any "defeat issues" that i have missed? the seat belt wires are not connected/unplugged, and i have not hard wired the fuel pump. does the h.s. relay compound the starting issues when not reconnected after being used? i know it's a band aid. first resort is r&r starter with one off of the fi motor, but it had a relay installed as well. i would prefer to eliminate issues before i spring for a starter up grade.
this one has me totally stumped. w/ key to on position, lows but no high beams. with fogs on, highs but no lows. oh man. i did nothing to the elec system other than all new fuses, cleaned all connections and removal of the a/c. this nightmare is not what i wanted to experience. anybody got a better starter laying on a shelve? kevin |
DNHunt |
Jun 4 2003, 09:41 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Boy Kevin I wish I could help ya out but the only thing I can offer is my experience with electrical issues has always been poor grounds. My car has never been apart and has never strayed far from stock wiring until this winter. You certainly are welcome to look at my car if you want. Give me a call and I'll swing by. Phone (253) 851-6447h, (253) 566-3440w. I'll try to be a little quieter than that hot rodder Geoff.
Give a call if I can help, Dave |
Jeffs9146 |
Jun 4 2003, 09:59 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I had a problem like that on my 67 911 once. I replaced the solinoid first and it worked twice then failed again. It turned out to be a bad starter! Check to see if the battery has enough Amperage not just voltage to engage the starter.
Just my 1.2 cents worth! Jeff |
tryan |
Jun 4 2003, 10:37 AM
Senior Member Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 |
yup, frustration. sounds like the starter needs a trip to
the shop. take it out and bench test it. the hot/hard start relay must have the body grounded. your key switch or power relay may be suspect from the symptoms. |
rhodyguy |
Jun 5 2003, 06:13 AM
all is good.
kevin |
Lawrence |
Jun 5 2003, 06:39 AM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
Did you fix it? What was the issue?
rhodyguy |
Jun 5 2003, 06:48 AM
well rusty, all can have a chuckle at my dopeyness. the bundle that contains the yellow wire that runs from the circuit board to the soleniod was off by one pin hole. no conection at the #6 pin= no power to the solenoid, plugged it in correctly and it cranked like a demon. i know all the grounds are squeeky clean now. (IMG:style_emoticons/default/boldblue.gif)
kevin |
Lo-Fi Version | Time is now: 5th May 2024 - 05:22 AM |
