electrical issues, starter, lights |
rhodyguy |
Jun 4 2003, 06:44 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
tried a crank over yest. nothing. the car came with a hot start relay. i disconnected it and ran the wires normaly. still nothing. shorted the two large soleniod terminals as per the lash book. starter spins, no solenoid engagement. is there any "defeat issues" that i have missed? the seat belt wires are not connected/unplugged, and i have not hard wired the fuel pump. does the h.s. relay compound the starting issues when not reconnected after being used? i know it's a band aid. first resort is r&r starter with one off of the fi motor, but it had a relay installed as well. i would prefer to eliminate issues before i spring for a starter up grade.
this one has me totally stumped. w/ key to on position, lows but no high beams. with fogs on, highs but no lows. oh man. i did nothing to the elec system other than all new fuses, cleaned all connections and removal of the a/c. this nightmare is not what i wanted to experience. anybody got a better starter laying on a shelve? kevin |
Jeffs9146 |
Jun 4 2003, 09:59 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I had a problem like that on my 67 911 once. I replaced the solinoid first and it worked twice then failed again. It turned out to be a bad starter! Check to see if the battery has enough Amperage not just voltage to engage the starter.
Just my 1.2 cents worth! Jeff |
Lo-Fi Version | Time is now: 18th May 2024 - 08:32 AM |
