Yet another blake bleeding question |
florida 914 |
Mar 21 2015, 09:17 PM
Newbie Group: Members Posts: 29 Joined: 29-September 10 From: Salem, OR Member No.: 12,227 Region Association: Pacific Northwest |
Sorry, folks, for asking yet another question about bleeding brakes, but I can't find the answer to this specific question and am at wits end.
I have a 1971 914. I am only able to get about a quarter of a pedal, i.e. it is off the floor, but only just, and no more improvement no matter how much we go through the routine. What seems weird is this: when I open the rear bleed nipples, the pedal goes to the floor (as my assistant pushes), but nothing like that happens on the front. I don't see air being pushed through on any corner any more, but there is fluid moving on all four corners (though probably more on the back than the front). And the pedal never pumps up better than a quarter or so even with all nipples closed. We have installed rebuilt calipers, new pads, new flex lines, and a new master cylinder (in fact, we tried a second new master cylinder on the theory that the first may have been faulty). As far as I can tell there is no clog in the fixed lines (we checked the front especially). Any suggestions? Thanks! |
stugray |
Mar 21 2015, 09:36 PM
Does your pedal cluster have the brake pedal return spring?
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.pelicanparts.com-10819-1426995412.1.JPG) Item #41 |
florida 914 |
Mar 22 2015, 12:52 AM
Does your pedal cluster have the brake pedal return spring? (IMG:http://www.914world.com/bbs2/uploads_offsite/www.pelicanparts.com-10819-1426995412.1.JPG) Item #41 I am not sure; I will have to take the pedal board off tomorrow to see. Either way I am very curious as to what effect that has..... |
screenguy914 |
Mar 22 2015, 01:21 AM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Don't understand the need to confirm the existence of a return spring. If the pedal doesn't retract on its own, there's an issue. If it does, look elsewhere. Since it's a new MC, there's a chance it's faulty. If it was the existing MC, I would suspect a cup was torn when the pedal went to the floor during the manual bleeding procedure.
Confirm the MC is creating pressure at the front and rear outlet ports. Simply remove the appropriate MC brake line and depress the pedal with a finger (or equivalent) blocking the port. Don't get brake fluid in your eyes. Sherwood |
rgalla9146 |
Mar 22 2015, 08:32 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The master cyl. can only take in more fluid if it comes back fully to the top of it's travel.
I don't think he would have gotten as far as he has if the there was no flow into the master. But, the spring is certainly important and should be checked. Any chance the front and rear circuits were switched at the master ? New hard lines ? |
76-914 |
Mar 22 2015, 08:55 AM
(IMG:style_emoticons/default/poke.gif) Who's Blake?
florida 914 |
Mar 22 2015, 10:37 AM
Blake is my assistant! That master cylinder was hard to get in ....
There is no problem with the pedal returning. This is the second new master cylinder I have tried with the same problem, though I suppose that could still be the issue. Back under there to undo ithe lines again..... |
76-914 |
Mar 22 2015, 10:54 AM
Did you bench bleed the MC?
florida 914 |
Mar 22 2015, 12:00 PM
Johny Blackstain |
Mar 22 2015, 12:44 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
Did you bench bleed the MC? No. I don't even know what that means. It means filling the MC w/ fluid & capping it before you install it. One of the possibilities available to you. Same applies to the proportioning valve in the rear. However, you can address these while the items are installed. With your assistant there, crack the lines on the MC while he remains up top & makes sure the reservoir does not go dry as you let the MC drip a bit. You should do the same for the proportioning valve in the rear although it's not as easy to do as the MC; your assistant might have to run between the pedal inside & the reservoir up front, making sure it never goes dry. Check the bushings & return spring on the pedal assembly as someone previously posted. Lastly, have you used a .004 feeler/gap gauge to adjust your rear calipers to the proper gap yet? You can also try tapping things w/ a screwdriver handle as you bleed to get the air bubbles to flow/move out. (IMG:style_emoticons/default/driving.gif) |
einic |
Newbie Group: Members Posts: 49 Joined: 28-May 10 From: Norway Member No.: 11,773 Region Association: Scandinavia |
Have you adjusted the push rod? You shold have just a tiny play before pressing the mc.
( The MC must return completely to relief pressure) |
pilothyer |
Mar 22 2015, 12:45 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Watch this, you can see what you need to do:
http://www.speedwaymotors.com/Tech/how-to-...r-cylinder.html |
stugray |
Mar 22 2015, 12:48 PM
Don't understand the need to confirm the existence of a return spring. If the pedal doesn't retract on its own, there's an issue. Exactly. The OPs original post sounded like the pedal was not returning. I am only able to get about a quarter of a pedal, i.e. it is off the floor, but only just... Then he clarified it here There is no problem with the pedal returning. It sounded like the pedal was not returning which would not pull new fluid in to the MC on each stroke. This sounds more like the classic bleed issue like this alleged "inability to purge the Prop valve". http://www.914world.com/bbs2/index.php?sho...225728&st=0 |
Tilly74 |
Mar 22 2015, 01:28 PM
Member Group: Members Posts: 96 Joined: 5-June 12 From: Springfield, MO Member No.: 14,522 Region Association: None |
My name is Blake. |
76-914 |
Mar 22 2015, 02:21 PM
My name is Blake. Well then florida914 has a question for you. He thinks your bleeding or something. |
florida 914 |
Mar 22 2015, 04:34 PM
Okay, I have now "bench bled" the MC, though I did it while it was on the car. That seemed to be getting lots of air out, so I thought I was on the right track. But I am still in the same situation.
Here is one thing I can't figure out: when we pump up the rear and then open the bleed valve the pedal goes to the floor. It also has a lot of flow on both sides of the rear. But that does not happen on the front. To the person pushing the pedal the pedal feels no different front from rear. It also does not have nearly so much flow in the front as the back (on either side). When I was bleeding the MC at the cylinder both front and back seemed the same. It seems like the pedal should go to the floor when the valve is opened, no? |
florida 914 |
Mar 22 2015, 04:39 PM
Also, when I put a wheel on it seems I do have braking in the back, but almost none in the front.
bigkensteele |
Mar 22 2015, 04:44 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Is it possible that you have the front calipers switched and the bleed valves are on the bottom? If this is the case, we have found your problem.
florida 914 |
Mar 22 2015, 04:58 PM
Is it possible that you have the front calipers switched and the bleed valves are on the bottom? If this is the case, we have found your problem. Um, maybe.... I definitely have the bleed valves on the bottom. I did not know it was possible to have them on backwards. Feeling kind of silly...but thanks! |
bigkensteele |
Mar 22 2015, 05:21 PM
Is it possible that you have the front calipers switched and the bleed valves are on the bottom? If this is the case, we have found your problem. Um, maybe.... I definitely have the bleed valves on the bottom. I did not know it was possible to have them on backwards. Feeling kind of silly...but thanks! I don't think that the rears can go on reversed but you should check them as well. Bleed valves have to be on top because that is where the air ends up. Don't feel silly. Feel happy that you have found the problem and that you will never make that mistake again. Better yet, you will be able to help the next guy who is asking this question. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:40 AM |
