Weltmeister short shifter and Factory Concole |
rfinegan |
Mar 22 2015, 01:00 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
I have just installed a Weltmiester short shifter in my 75 914. I test drove and the shifting has greatly improved. I am very happy it the way it works and shifts. However it sits a bit higher then the factory unit and installing the shift boot and bottom for the console is troublesome. Any one have any advice how they resolved this? I hate t have to cut a nice console but the shift improvements of the short shifter are here to stay and the stock unit is not going back in
-Robert |
914Sixer |
Mar 22 2015, 08:14 AM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You might want to make up a couple of spacers to raise up the ends of the console to keep it level.
pcar916 |
Mar 22 2015, 09:40 AM
When I had one I made rock-maple spacers under each end to raise the console shelf rather than the entire console. Although, since my console was the shorter A/C version, there was plenty of room where the A/C unit had been.
That means I could have raised the entire console, but I figured it would let too much dirt in around the edges. Good Luck |
rfinegan |
Mar 23 2015, 05:06 AM
The lower bottom of the console rides a little high in the back but over all looks pretty good...
Thanks Ya'll Im going to firm this us and make it more permanent -Robert Attached thumbnail(s) |
bcheney |
Mar 23 2015, 10:42 AM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
When you say it sits higher do you mean that the bottom of the shift rod spline end where it couples with the shifter end up sitting higher? Just wondering because I have a little issue with that area on my shift rod....it seems to touch the top side of the clutch tube that was re-welded in place years ago. Wonder if moving to this short shifter set up might help that...
larryM |
Mar 23 2015, 09:13 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
yes, that's the way it is - always was 20 yrs ago - i just left out the "floor" and put carpet in there |
rfinegan |
Mar 24 2015, 05:17 AM
The added length below the pivot ball is longer so that the throw is increased with less movement on the handle end. to keep things "lined up", a spacer is placed under the body of the shifter raising everything up and keeping things in line with the shift linkages. This is why the shifter housing is now touching and pressing up on the "floor" of the center console ( shift boot ring) and console mounts. It sound like you would have the same issues with the stock or short shift if I am reading things right When you say it sits higher do you mean that the bottom of the shift rod spline end where it couples with the shifter end up sitting higher? Just wondering because I have a little issue with that area on my shift rod....it seems to touch the top side of the clutch tube that was re-welded in place years ago. Wonder if moving to this short shifter set up might help that... |
Lo-Fi Version | Time is now: 21st May 2024 - 03:06 AM |
