FS Porsche 914-4 Rebuilt BOGE Struts With 5 Lugs |
hencar |
Mar 22 2015, 01:53 PM
Member Group: Members Posts: 73 Joined: 30-May 06 From: Little Rock, Arkansas Member No.: 6,097 |
This ad is for a pair of OEM BOGE strut assemblies for a 1973 - 1976 Porsche 914-4. The struts have been media blasted and epoxy coated black and include a pair of yellow Bilstein inserts. The left and right ATE "M" brake calipers were rebuilt by PMB Performance Products and include brake pads and brake lines.
In addition there are two new cross drilled cryogenic treated rotors with new wheel bearings and seals. The rotors have been professionally drilled for a Porsche 911 or 914-6 for use with Fuchs alloy rims or alternatives with a standard 5 X 130mm bolt pattern. The cross drilled rotors have studs installed and come with steel lug nuts. Everything you need for a 5 bolt conversion for the front of your Porsche 914 I am asking $750.00 for the setup plus $112.00 in postage and paypal fees Thanks in advance for your interest. Henry Attached image(s) |
fduval |
Mar 23 2015, 08:49 AM
Newbie Group: Members Posts: 41 Joined: 2-January 13 From: quebec Member No.: 15,331 Region Association: Canada |
This ad is for a pair of OEM BOGE strut assemblies for a 1973 - 1976 Porsche 914-4. The struts have been media blasted and epoxy coated black and include a pair of yellow Bilstein inserts. The left and right ATE "M" brake calipers were rebuilt by PMB Performance Products and include brake pads and brake lines. In addition there are two new cross drilled cryogenic treated rotors with new wheel bearings and seals. The rotors have been professionally drilled for a Porsche 911 or 914-6 for use with Fuchs alloy rims or alternatives with a standard 5 X 130mm bolt pattern. The cross drilled rotors have studs installed and come with steel lug nuts. Everything you need for a 5 bolt conversion for the front of your Porsche 914 I am asking $750.00 for the setup plus $112.00 in postage and paypal fees Thanks in advance for your interest. Henry Hi , interrested in these........ pm sent |
Lo-Fi Version | Time is now: 27th May 2024 - 06:36 PM |
