Want a smoother ride, Is this possible? |
jack20 |
Mar 22 2015, 11:56 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
I returned to a 914 after 32 yrs. I don't remember my last one, a 74, riding so rough.
This new 74 rattles my teeth. I did the old school bounce test on the fenders to check the shocks and it only bounced once. Is this a valid test on these cars? The PO did lower the front and that may account for some of the rough ride. Not sure how old the shocks are...could be original...yet they did pass the bounce test... Should I replace them for a better ride? Thanks, Jack |
Chris Pincetich |
Mar 23 2015, 12:10 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
New suspension bushings make a world of a difference (IMG:style_emoticons/default/beerchug.gif)
Like JStroud said - almost a waste of $$ to replace shocks first. I went with an expensive needle-bearing setup. Very little friction and zero sticktion. I feel some chassis vibration because they are basically solid and unforgiving, but the car "floats" over most bumps. I rebuilt the entire suspension on my 914 and have yet to do much engine work at all (IMG:style_emoticons/default/beerchug.gif) |
ConeDodger |
Mar 28 2015, 10:59 AM
Apex killer! Group: Members Posts: 23,587 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
New suspension bushings make a world of a difference (IMG:style_emoticons/default/beerchug.gif) Like JStroud said - almost a waste of $$ to replace shocks first. I went with an expensive needle-bearing setup. Very little friction and zero sticktion. I feel some chassis vibration because they are basically solid and unforgiving, but the car "floats" over most bumps. I rebuilt the entire suspension on my 914 and have yet to do much engine work at all (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) I have little doubt your factory bushings are basically made of rock now. You can test this by taking the wheel off and disconnecting the shock. Then, push up on the control arm. Can't move it? That's stiction. I used Elephant Bushings and when you do that same test, you can easily and smoothly move it through it's entire range of motion. This is the point at which your shocks become relevant. Now they can actually do the job. You can't believe how they suck up road imperfections. I highly recommend them. |
Lo-Fi Version | Time is now: 16th May 2024 - 05:52 AM |
