Need Photos/Diagrams to help hook up L-Jetronic FI on 1975 Porsche 914 2.0L 4cyl, L-Jetronic Help |
91422.7 |
Mar 25 2015, 12:36 PM
Newbie Group: Members Posts: 36 Joined: 8-October 14 From: Eugene, Oregon Member No.: 17,991 Region Association: Upper MidWest |
I'm in the process of installing a L-Jetronic Fuel Injection System on a 1975 Porsche 914 2.0L engine, which I'm installing the engine etc. in a 1970 914 body. The FI system was reportedly from a 1975 914 engine along with the engine. I'm needing some good photos or good diagrams that will help locate where all the wiring goes.
Items I've been working from: 1) Haynes 914 Owners Workshop Manual 2) Internet flow charts and electrical charts From the attached photos, you can see on the FI wiring harness I have several wires that are hanging loose. I believe the ones on the p/s the 4 wires together go to the MPC Sensor in the picture. Anyhow any help would be appreciated. From the picture you can see I have the wires going to the 4 injectors hooked up, not sure if they are going to the correct injector but I don't think it matters! When I purchased the 2.0L Engine it had twin carbs on it, it possibly had some parts removed. I think some of the wires go to the following items: 1) Cylinder head temp sensor 2) EGR Valve (which isn't going to be used on exhaust) 3) MPC Sensor (4 wire plug in) 4) Intake Manifold Temp Sensor 5) Thermostat Switch 6) Cold Start Valve 7) Engine Speed Relay 8) Throttle Valve Switch 9) Vacuum advance Disconnection 2-way valve 10) To starter terminal .....Maybe I've answered my own questions? (IMG:style_emoticons/default/driving.gif) Attached image(s) |
Bleyseng |
Mar 26 2015, 08:03 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Buy all the rubber boots for the plugs as without them the FI plugs will come off. Or send the FI harness to Jeff with all the pieces to be rebuilt.
What ECU do you have? look for the model numbers What MPS do you have? What injectors do you have? They need to match year wise. (IMG:style_emoticons/default/chair.gif) |
91422.7 |
Mar 26 2015, 03:33 PM
Buy all the rubber boots for the plugs as without them the FI plugs will come off. Or send the FI harness to Jeff with all the pieces to be rebuilt. What ECU do you have? look for the model numbers What MPS do you have? What injectors do you have? They need to match year wise. (IMG:style_emoticons/default/chair.gif) Bleyseng; Thanks for the additional info about the FI plugs and I will have to check the numbers on the FI parts! |
Lo-Fi Version | Time is now: 16th May 2024 - 05:52 PM |
