EFI throttle body recommendations, replacing carbs |
tommy914 |
Feb 13 2005, 10:38 PM
Life is a journey, enjoy every turn. Group: Members Posts: 1,103 Joined: 15-September 03 From: Ridgeland, MS Member No.: 1,165 Region Association: None |
I want to replace my Weber Carbs with EFI.
Any recommendations for throttle bodies? Weber, TWM, CB performance, others? Which fuel pump is best? what PSI and GPH specs should I be looking for. Is a fuel pressure regulator required? vacuum operated? Which injectors? I'm gonna start out trying Megasquirt, if that doesn't work out, I'll be looking for an off the shelf EMS. thanks |
Lo-Fi Version | Time is now: 1st June 2024 - 05:50 AM |
