Pictures of my 914/6 project, Done by 9/14... ? |
siverson |
Jun 4 2003, 12:45 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
Click here for the pictures
(IMG:style_emoticons/default/driving.gif) I thought I'd share some pictures of my progress on my car, and ask a bunch of questions at the same time. A little background... I've owned the car for about 12 years now, drove it around with a 2.0 four for about 7 years, then converted to a 6-cyl 3.6 liter engine, drove it around for about 2 years like that, and now about three years ago I started to take it all apart (again) and do all the things with the conversion that I didn't have the time or money to do the first time (I did the whole 3.6 conversion in about 3 weekends the first time, and was still about 3 days late getting back to college!) Anyways... The "re-version" includes: - factory steel GT flares - carbon fiber front and rear lids - extensive chassis reinforcement - 13" front rotors, 993TT front calipers - Vellios trailing arm adapter, carrera rear wheel bearing, carrera e-brake, 930 rear rotor, C2T rear calipers - 964 3.6 engine, rebuilt by Andial with Euro RS cams and a couple other fun things - rebuilt '84 915 w/ factory LSD (Vellios adapter) - and that's all I can think of at the moment... (And yes, just to be clear, I agree with all the Vellios bashing that occurs on this board. The parts are pretty nice once you get them to work, but they are far from complete and George Vellios is an extremely difficult person to work with. I wouldn't purchase them again...) Questions: - Any problems that you can see from any of these pictures? I'd appreciate any critique. In particular, do I have any of the rubber installed backwards or incorrectly? For example, the front rear trunk (if that makes any sense) is asymmetrical, but seems like it would function fine either way, but I'm sure there is a correct way. - At this point, it seems like it would be just as easy to run braided -3 or -4 line for the brakes, or reinstall the factory hard lines. Any reason I should choose one of the other? I'd like to also install a cockpit mounted front/rear brake bias adjuster. - Do I need those back metal "dust-cover" things for the rotors? I currently don't have them on the front or rear. Am I going to really regret not having them after the first couple hundred miles, or is it no big deal? If so, I'll have to figure out how to adapt some sort of 13" cover from a C2T or 993TT, because the early 911 covers that fit on my struts or rear trailing arm now are way too small for the rotors. - All the rubber is OEM Porsche, but the rubber on the door (long piece) seems to fit so fugly. I've got to be doing something wrong... - What do you think about my cheesy plastic "grommets" I made from the plastic wire loom stuff? Anyone have a source for something better? Some nice, smooth, high-temperature resistant rubber would be nice. It's primary used to protect braided oil lines where they pass through the body. - Anyone have a Bosch Hammer (KTS-300 or KTS-500) (aka Porsche tester 9288) for sale? - What's the best way to remove super glue from chrome? (Sigh... don't ask.) Thanks for any tips! Click here for the pictures Attached image(s) |
siverson |
Jun 4 2003, 01:20 PM
Thanks - that is the Brad Meyeur (sp?) longitudinal kit. The car was/is about as rust free as 914s come (Arizona then California car), but the door gaps started to look worse after having the 3.6 in for about 18 months. The chassis reinforcement was one of the big reasons to undertake this project.
I haven't driven a car with the kit yet, but so far, I love it - even on a rust free chassis. It does add quite a bit of weight, but it just seems so much stronger now. Even when jacking the car up it just feels rock solid. This is how I learned to weld! Attached image(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 07:50 AM |
