Engine Oil for Stock 914-6 with 80K miles |
xsurfer |
Mar 27 2015, 08:43 AM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
Is 30 weight oil still the best to run in the stock engine? If not?
Thanks |
SLITS |
Mar 27 2015, 08:57 AM
20 - 50 oils with lots of ZDDP.
Kendall GT with Liquid Titanium Royal Purple Valvoline VR1 Racing Oil Brad Penn Jake Raby's Snake Oil and a few more I don't remember. Straight 30w would be fine if it has the ZDDP @ 1200 ppm or better, but with high temps I would prefer the multi-grade. |
Mark Henry |
Mar 27 2015, 09:11 AM
Chevron Delo 400 15-40, good dino oil, lots of ZDDP, a lot like what Shell Rottella T used to be.
Made for diesel, cheap, I've been using it with no issues. It's in my T4 nickies engine, using it in several friends Type 1, /4 and /6 engines. I also use it in my Fiat tractor. I'll be using it in my fresh 3.0 engine. Recommended by Supertec. |
fixer34 |
Mar 27 2015, 10:04 AM
Senior Member Group: Members Posts: 1,072 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Stock /6, I used to use Castrol GTX 20-50. Been using Shell Rotella T 15W-40 'Triple Protection' lately on advice from another board. Is it not as good as it was (ZDDP?). |
stugray |
Mar 27 2015, 10:19 AM
Here is a recent article about ZDDP.
It even talks about the changes in recipes like Jake mentions: http://speedtalk.com/forum/viewtopic.php?f=15&t=42719 You would need to make a login acct to view, but there is some good stuff on that site. Here is the chart of the results of how much zinc is in each: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1427473151.1.png) So I think I will go with the VR1 if on a budget and the Joe Gibbs if I win the lottery. |
gfg3 |
Mar 27 2015, 10:45 AM
Never Too Old Group: Members Posts: 117 Joined: 5-January 15 From: Southern Virginia Member No.: 18,295 Region Association: None |
Valvoline VR1 20W50....recommended by several engine builders for both /4 and /6 engines.
George |
pete000 |
Mar 27 2015, 11:39 AM
Whats the best source for the Valvoline VR1?
gfg3 |
Mar 27 2015, 11:48 AM
stugray |
Mar 27 2015, 11:57 AM
Whats the best source for the Valvoline VR1? I get my 20w50 VR1 at the local Advance Auto Parts store. About $6 per qt. George And if my memory serves me right, it is just about the time of year that it goes on sale. So keep an eye out. It's $5.99 a qt at advance auto, and if you order before tomorrow you can get an additional 15% off if you order online by using the online coupon (upper right corner) of webpage http://shop.advanceautoparts.com/p/valvoli...mp;prefZC=80501 |
screenguy914 |
Mar 27 2015, 12:42 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
mskala |
Mar 27 2015, 01:43 PM
Has something changed with the Rotella T?
somd914 |
Mar 27 2015, 03:05 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Whats the best source for the Valvoline VR1? I get my 20w50 VR1 at the local Advance Auto Parts store. About $6 per qt. George (IMG:style_emoticons/default/agree.gif) Just changed my last weekend. Also an interesting read here, how accurate it is who knows, but the manufacturers jump in and make claims w/o test data... http://speedtalk.com/forum/viewtopic.php?f=1&t=35836 |
patssle |
Mar 27 2015, 05:19 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Stock /6, I used to use Castrol GTX 20-50. Been using Shell Rotella T 15W-40 'Triple Protection' lately on advice from another board. Is it not as good as it was (ZDDP?). Castrol GTX is junk. I used it as my first oil post-6 conversion since it was cheap in case I needed to pull the engine back out. But did a bunch of research for my first oil change and will never touch that stuff again. Running VR-1 here as well - the ZDDP numbers are pretty solid for 20w50...Advanced has it for $6/quart which is about the same price as Mobil1 at Wal-Mart! |
PancakePorsche |
Mar 27 2015, 11:49 PM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
+1 for VR-1 20/50
On the shelf at O'Reilly 135K mi on my engine still strong with next to no oil consumption. Good stuff. |
skier2.0 |
Mar 28 2015, 06:38 PM
Newbie Group: Members Posts: 34 Joined: 30-May 14 From: United States Member No.: 17,422 Region Association: MidAtlantic Region |
Its a 6 SOHC not a pushrod flat tappet engine. ZDDP is important on the fours not so much on the sixes. I run Mobil1 15-50.
Lo-Fi Version | Time is now: 18th April 2024 - 02:57 PM |
