Engine Oil for Stock 914-6 with 80K miles |
xsurfer |
Mar 27 2015, 08:43 AM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
Is 30 weight oil still the best to run in the stock engine? If not?
Thanks |
fixer34 |
Mar 27 2015, 10:04 AM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Stock /6, I used to use Castrol GTX 20-50. Been using Shell Rotella T 15W-40 'Triple Protection' lately on advice from another board. Is it not as good as it was (ZDDP?). |
patssle |
Mar 27 2015, 05:19 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Stock /6, I used to use Castrol GTX 20-50. Been using Shell Rotella T 15W-40 'Triple Protection' lately on advice from another board. Is it not as good as it was (ZDDP?). Castrol GTX is junk. I used it as my first oil post-6 conversion since it was cheap in case I needed to pull the engine back out. But did a bunch of research for my first oil change and will never touch that stuff again. Running VR-1 here as well - the ZDDP numbers are pretty solid for 20w50...Advanced has it for $6/quart which is about the same price as Mobil1 at Wal-Mart! |
Lo-Fi Version | Time is now: 22nd May 2024 - 10:47 AM |
