show and help, show your 4 cylinder and specs |
rube914 |
Mar 28 2015, 09:35 AM
Newbie Group: Members Posts: 3 Joined: 20-March 15 From: seattle Member No.: 18,541 Region Association: None |
Hello 914 world I'm new to all of this.I just picked up a 914 with a bored out motor and want to see other builds out there for reference.I'm also wanting to soak up as many info as possible to get my motor running smooth..let's see what your running, bore size, fi or carbs, exhaust..pictures are welcome.thanks alot
I'll start:).I'm running a 2400cc .I was told it's a 72 stroke by 103.stock fuel injection.stock injectors.009 dizzy with a nice flame thrower kit with performance wires quad chrome tipped monza exhaust.it runs like a bag of door knobs. (IMG:style_emoticons/default/WTF.gif) Attached thumbnail(s) |
falcor75 |
Mar 28 2015, 09:57 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Stock fuel injection on a 2400? From what I've read on here I dont think that will work very well, you need to go carb or EFI.
Mike Bellis |
Mar 28 2015, 10:05 AM
Ditch the 009 & monza exhaust too.
Java2570 |
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Need more info on what else is in that engine but I'd definitely say get rid of that 009 dizzy, they aren't meant to run on 914 engines. And I agree, stock D jet isn't going to get you very far with a 2.4....talk to Mario @ Dubshop about Megasquirt setups. Or Nate at ProVolks is a great resource in your area.....http://www.aircooledtech.com/provolks/
somd914 |
Mar 28 2015, 12:12 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/agree.gif) - shed the dizzy, go with Mallory, a decent SVDA, etc. And the stock FI won't feed it. Beyond the Monza muffler, stock heat exchangers or headers?
Im running a 2056 with dual Weber 40's, stock 2.0 heads, Webcam 86 cam, SVDA dizzy, stainless heat exchangers, magna flow muffler. A common build, but overall, a nice improvement over the stock 2.0. Took a while to get the carb jetting worked out, but once I got that they have been easy to maintain. |
Mar 28 2015, 03:18 PM
Custom Member Group: Members Posts: 24,560 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Ok,
the stock Djet with tuning runs a 2.4 liter motor, proven to work, by me. I had to know cause everyone said it would not, but when you look at the specs, it should. Indeed it works, runs, drives, does everything it should...but the camshaft keeps it restricted. Couple of facts. With Djet, you need the Djet EFI trigger points in the base of the distributor, so you are not running djet. With Ljet, you need a firing signal from the points, so it may have Ljet. Ljet is easier to tune for a 2.4 liter motor. On the cheap, I would source a used ljet distributor to give you a better advance curve and get it back to stock. The tuning will be tricky, but it can be done if you do some research. Combination of a resistor in the CHT circuit, and adjusting the AFM will get you with a race ready 2.4 liter motor, running Ljet. So, take more pictures, learn more. You ahve a 71mm crank and 103 Mm pistons. ITs just shy of 2.4 liters. Check the head casting numbers to see what type of heads you have before you throw too much money at it... Remove the valve covers, the head number is inside, Take a pic, post it here. rich |
Al Meredith |
Mar 28 2015, 04:09 PM
Senior Member Group: Members Posts: 958 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
103s tend to overheat with stock cooling hardware. so to a 2.4
somd914 |
Mar 28 2015, 04:29 PM
the stock Djet with tuning runs a 2.4 liter motor, proven to work, by me. I had to know cause everyone said it would not, but when you look at the specs, it should. Indeed it works, runs, drives, does everything it should...but the camshaft keeps it restricted. Like you I've always heard beyond a 2056 you need to move away from D-Jet or L-Jet, but unlike you I took it as gospel. Thanks for the info. |
jpapatrout |
Mar 28 2015, 08:58 PM
Newbie Group: Members Posts: 12 Joined: 7-October 09 From: SoCal - Palm Springs Member No.: 10,903 Region Association: Southwest Region |
Ok, the stock Djet with tuning runs a 2.4 liter motor, proven to work, by me. I had to know cause everyone said it would not, but when you look at the specs, it should. Indeed it works, runs, drives, does everything it should...but the camshaft keeps it restricted. Couple of facts. With Djet, you need the Djet EFI trigger points in the base of the distributor, so you are not running djet. With Ljet, you need a firing signal from the points, so it may have Ljet. Ljet is easier to tune for a 2.4 liter motor. On the cheap, I would source a used ljet distributor to give you a better advance curve and get it back to stock. The tuning will be tricky, but it can be done if you do some research. Combination of a resistor in the CHT circuit, and adjusting the AFM will get you with a race ready 2.4 liter motor, running Ljet. So, take more pictures, learn more. You ahve a 71mm crank and 103 Mm pistons. ITs just shy of 2.4 liters. Check the head casting numbers to see what type of heads you have before you throw too much money at it... Remove the valve covers, the head number is inside, Take a pic, post it here. rich |
worn |
Mar 28 2015, 09:00 PM
can't remember Group: Members Posts: 3,143 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Rich, does the 009 even have trigger points? I thought it was a dizzy for carbs.
Sounds like a non-beginner engine here. But that isn't a reflection on the poster, just the motor sounds like a handful. Good luck with the cool motor. |
worn |
Mar 28 2015, 09:06 PM
As for what people have, I built a 2056 with stock FI a modified cam, and modified (aluminum chopper) electronic ignition from Crane. Biggest mods were A/F and CHT gauges. Still runs too lean or too hot, your pick. But it's my favorite car. Yes, my wife's van is faster, why do you ask?
Lo-Fi Version | Time is now: 19th April 2024 - 05:59 AM |
