Broken MPS, Start after rebuild |
DavidSweden |
Mar 29 2015, 12:00 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I have rebuilt my 2.0 engine and plan to install during Easter. I discovered that my MPS does not hold a vacuum, I have a rebuilt unit on order from Automobile Atlanta but it will probably some weeks until delivery
Question: Can I do the first motor start and run it for 20 mins @ 2000rpm with the broken MPS? Thanks |
TheCabinetmaker |
Mar 29 2015, 12:11 PM
Depends on what is "broken". If it's not holding vacuum then it's running full rich which could wash the cylinders with fuel and waste your rings.
OU8AVW |
Mar 29 2015, 12:25 PM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
You'll probably run too rich and foul out your plugs. That's what mine did. Cancel that AA order and get one from Jeff Bowlsby.
JeffBowlsby |
Mar 29 2015, 06:27 PM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
An 043 MPS is headed for Sweden soon. (IMG:style_emoticons/default/smile.gif) Thanks Mike.
Lo-Fi Version | Time is now: 17th May 2024 - 06:43 AM |
