Motor Mount bolt size/length?, (outer mounts for side shift trans motor bar) |
BuddyV |
Mar 29 2015, 12:51 PM
Robert Group: Members Posts: 555 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
I am installing a 2.0 with a side shift trans...... I need to buy the outer volts that attach the motor mount bar to the underside of the car. I have only had tail shift cars until now....
What size bolt (and length) do I use. I thought I had heard M10 x ? Also, just (2) washers and nylon lock nut for each side??? I peeked under the car at the mounting pint, and there seems to be a platform mounted in the circular opening..... does this platform restrict the use of a standard washer??? Thank you for your help..... hoping bolts/washers/nuts are easily found at my local hardware store...... but please let me know if there are any "special" parts that I should know about. Cheers! |
Dave_Darling |
Mar 29 2015, 06:56 PM
Actually, the washers are not standard ones. They are not a complete circle on the outside, but have two flat edges so that they fit in the U channel piece. (See #22 in the diagram above.)
--DD |
Lo-Fi Version | Time is now: 17th May 2024 - 09:24 PM |
