Porsche 914 Starter/Wiring/Vacuum Hose Questions, Wiring and Vacuum Hose Questions |
91422.7 |
Mar 29 2015, 09:12 PM
Newbie Group: Members Posts: 36 Joined: 8-October 14 From: Eugene, Oregon Member No.: 17,991 Region Association: Upper MidWest |
Having problems getting the starter to engage! I have a 1970 Porsche 914 which I've just installed a 1975 914 2.0L F.I. engine. I've attached a photo of the starter hookup. It appears from the starter solenoid there is a blue wire or red/black wire that suppose to go to the ignition switch! Does that wire actually go to the Fuse Relay Block Panel first then on to the ignition switch? Question #2: from the picture you can see the Air Aux Regulator which has 2 outlets, one comes from the air breather, where does the other one go? Question #3: One of the injectors slides in and out pretty easy, the other 3 don't, is that because the one has a faulty inner rubber seal? Question #4: Is there a problem using the 1970 Fuse Relay Block (Engine Compartment) since I'm using a later model (1975) 2.0L F.I. engine or do I need to upgrade to a FRB out of a 1975 914? Thanks again for all your help!
Attached image(s) |
JeffBowlsby |
Mar 29 2015, 10:27 PM
914 Wiring Harnesses Group: Members Posts: 8,439 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Two issues I see:
That big yellow wire on the igniotin harness that is just hanging, must attach to the starter. See here for the vacuum hose layout for the AAR: http://bowlsby.net/914/Classic/TechNotebook.htm That ignition harness you have is not correct for a 75 2.0L, it is an Ljet harness. Will not work with a standard 2.0L setup. The relay board is compatible with all 914/4 cars. |
91422.7 |
Mar 29 2015, 10:44 PM
Two issues I see: That big yellow wire on the igniotin harness that is just hanging, must attach to the starter. See here for the vacuum hose layout for the AAR: http://bowlsby.net/914/Classic/TechNotebook.htm That ignition harness you have is not correct for a 75 2.0L, it is an Ljet harness. Will not work with a standard 2.0L setup. The relay board is compatible with all 914/4 cars. Ok Jeff, thanks again...I'm on it! (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 28th March 2024 - 07:23 PM |
