Porsche 914 Starter/Wiring/Vacuum Hose Questions, Wiring and Vacuum Hose Questions |
91422.7 |
Mar 29 2015, 09:12 PM
Newbie Group: Members Posts: 36 Joined: 8-October 14 From: Eugene, Oregon Member No.: 17,991 Region Association: Upper MidWest |
Having problems getting the starter to engage! I have a 1970 Porsche 914 which I've just installed a 1975 914 2.0L F.I. engine. I've attached a photo of the starter hookup. It appears from the starter solenoid there is a blue wire or red/black wire that suppose to go to the ignition switch! Does that wire actually go to the Fuse Relay Block Panel first then on to the ignition switch? Question #2: from the picture you can see the Air Aux Regulator which has 2 outlets, one comes from the air breather, where does the other one go? Question #3: One of the injectors slides in and out pretty easy, the other 3 don't, is that because the one has a faulty inner rubber seal? Question #4: Is there a problem using the 1970 Fuse Relay Block (Engine Compartment) since I'm using a later model (1975) 2.0L F.I. engine or do I need to upgrade to a FRB out of a 1975 914? Thanks again for all your help!
Attached image(s) |
isdyl |
Nov 8 2018, 04:32 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi - Sorry to resurrect an old thread but I'm having a similar starting problem which I think is due to a voltage drop between the ignition switch and the starter solenoid (yellow wire). It starts sometimes fine, but other times there is a short delay with the key held in the 'crank' position, and sometimes nothing at all. I was thinking of installing a 4-pole solenoid to eliminate the problem which I have done on a VW camper with success, but am just thinking of trying to clear any poor connections first. From what I can see the yellow wire from the starter solenoid goes back to the Regulator Plate. Please see attached a pic of my plate which is in a pretty dirty condition. I just wondered if anyone could tell me which wire/plug goes from the Reg Plate back to the ignition switch please? Also I should add that the car has been converted to carbs so thats why not all wires are present on the plate.
Many thanks Attached image(s) |
barefoot |
Nov 8 2018, 06:53 AM
Senior Member Group: Members Posts: 1,269 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Hi - Sorry to resurrect an old thread but I'm having a similar starting problem which I think is due to a voltage drop between the ignition switch and the starter solenoid (yellow wire). It starts sometimes fine, but other times there is a short delay with the key held in the 'crank' position, and sometimes nothing at all. I was thinking of installing a 4-pole solenoid to eliminate the problem which I have done on a VW camper with success, but am just thinking of trying to clear any poor connections first. From what I can see the yellow wire from the starter solenoid goes back to the Regulator Plate. Please see attached a pic of my plate which is in a pretty dirty condition. I just wondered if anyone could tell me which wire/plug goes from the Reg Plate back to the ignition switch please? Also I should add that the car has been converted to carbs so thats why not all wires are present on the plate. Many thanks Here's a diagram of the relay board, you can trace the wire going back to the ign switch on there. |
Lo-Fi Version | Time is now: 25th April 2024 - 05:02 AM |
