Porsche 914 Starter/Wiring/Vacuum Hose Questions, Wiring and Vacuum Hose Questions |
91422.7 |
Mar 29 2015, 09:12 PM
Newbie Group: Members Posts: 36 Joined: 8-October 14 From: Eugene, Oregon Member No.: 17,991 Region Association: Upper MidWest |
Having problems getting the starter to engage! I have a 1970 Porsche 914 which I've just installed a 1975 914 2.0L F.I. engine. I've attached a photo of the starter hookup. It appears from the starter solenoid there is a blue wire or red/black wire that suppose to go to the ignition switch! Does that wire actually go to the Fuse Relay Block Panel first then on to the ignition switch? Question #2: from the picture you can see the Air Aux Regulator which has 2 outlets, one comes from the air breather, where does the other one go? Question #3: One of the injectors slides in and out pretty easy, the other 3 don't, is that because the one has a faulty inner rubber seal? Question #4: Is there a problem using the 1970 Fuse Relay Block (Engine Compartment) since I'm using a later model (1975) 2.0L F.I. engine or do I need to upgrade to a FRB out of a 1975 914? Thanks again for all your help!
Attached image(s) |
isdyl |
Nov 9 2018, 05:41 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi - no it's not the ignition switch as I took the wires off and tried 'hot wiring'. Same symptoms - a delay and then sometimes cranking. I'm getting 8 volts at the solenoid so I'll try cleaning up the plug connections on the plate, and maybe just connecting the two wires together and see if that works. If no good I'll just have to fit the little black relay. I'll install it near the relay/regulator plate as it doesn't look waterproof.
Dylan |
Lo-Fi Version | Time is now: 20th April 2024 - 07:19 AM |
