Installing my Triad Exhaust - couple of questions, Modeeator will you pls move this to garage? |
914Next |
Mar 30 2015, 02:56 PM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
Just received my Triad exhaust from Dave. Thanks, Dave. Excited to get it installed but will likely be a day or two since I'll take the opportunity to do some cleaning up while I have a bit more room with the stock exhaust out.
Couple of questions: - can the gaskets that were on the stock exhaust be re-used? They don't look too bad. Just not sure if new ones need to be used when replacing the exhaust. Assume there is no type of sealant used on the gaskets? Just bolt it up? If I need new ones, where do I get them? - As would be expected, five nuts came off very easily with the help of some liquid wrench. One bolt however resisted and snapped. Where can I get a replacement? Will be sure to video the new exhaust sound when I get it all wrapped up. Thanks. Steve |
Lo-Fi Version | Time is now: 17th May 2024 - 03:30 PM |
