Heater cable issues, Heater cable nightmares |
Synchromesh |
Apr 3 2015, 02:17 PM
Newbie Group: Members Posts: 15 Joined: 20-December 14 From: San Francisco Member No.: 18,241 Region Association: None |
I have a '75 914. The original heater system was dismantled by one of the previous owners. I've been slowly rebuilding it back.
At this point I'm on the last piece of it. I got the heater valves in place and the cable on that end seems to be just fine. However, I took my floor lever apart and realized that the cable is pretty broken. (See attached pic). So my question is - how hard is it to put that thing in and what exactly mounts it to the lever? There is a small hole in the bottom of it but I can't figure it out. Obviously I'll have to buy a new one. Thanks. |
sbsix |
Apr 3 2015, 02:25 PM
only the lead dog enjoys a change in scenery... Group: Members Posts: 450 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
The heater cable is just bent in a "V" shape at the lever end. No other attachment needed. It's not a bad replacement but the car needs to be jacked up (use jack stands) and just tape the "V" end of the new cable to the old and pull it back past the bulkhead to the lever.
Jonathan Livesay |
Apr 3 2015, 02:27 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
The cable should be 1 long piece threaded through the hole in the lever and then down the 2 guide tubes just behind where the lever bolts on and out through the ends of the tubes at the firewall. It looks like yours snapped at the V bend at the lever. Threading it through is a bit fussy, good luck.
DavidSweden |
Apr 3 2015, 02:29 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I have a '75 914. The original heater system was dismantled by one of the previous owners. I've been slowly rebuilding it back. At this point I'm on the last piece of it. I got the heater valves in place and the cable on that end seems to be just fine. However, I took my floor lever apart and realized that the cable is pretty broken. (See attached pic). So my question is - how hard is it to put that thing in and what exactly mounts it to the lever? There is a small hole in the bottom of it but I can't figure it out. Obviously I'll have to buy a new one. Thanks. Its a very easy job. I did it today it took about half an hour. The 2 wires back to the heater boxes is actually 1 wire which runs in separate metal tubes from the lever back to the heater boxes. If you look into the tunnel you will see the tubes. On the end of the lever there is a small hole. The wire runs from one heater box thru the tube then thru hole in the bottom of the lever and back down the other tube to the second heater box. Did that make sense hope you understood. |
Synchromesh |
Apr 3 2015, 02:35 PM
I have a '75 914. The original heater system was dismantled by one of the previous owners. I've been slowly rebuilding it back. At this point I'm on the last piece of it. I got the heater valves in place and the cable on that end seems to be just fine. However, I took my floor lever apart and realized that the cable is pretty broken. (See attached pic). So my question is - how hard is it to put that thing in and what exactly mounts it to the lever? There is a small hole in the bottom of it but I can't figure it out. Obviously I'll have to buy a new one. Thanks. Its a very easy job. I did it today it took about half an hour. The 2 wires back to the heater boxes is actually 1 wire which runs in separate metal tubes from the lever back to the heater boxes. If you look into the tunnel you will see the tubes. On the end of the lever there is a small hole. The wire runs from one heater box thru the tube then thru hole in the bottom of the lever and back down the other tube to the second heater box. Did that make sense hope you understood. Ah! Now I see exactly what you're talking about. Very useful, thanks. So I need to pull the broke one out. But the question is this: there are 2 thicker ends that go into the barrels on the heater valves. Would one of them fit through the little hole on the lever? |
Apr 3 2015, 03:10 PM
I have a '75 914. The original heater system was dismantled by one of the previous owners. I've been slowly rebuilding it back. At this point I'm on the last piece of it. I got the heater valves in place and the cable on that end seems to be just fine. However, I took my floor lever apart and realized that the cable is pretty broken. (See attached pic). So my question is - how hard is it to put that thing in and what exactly mounts it to the lever? There is a small hole in the bottom of it but I can't figure it out. Obviously I'll have to buy a new one. Thanks. Its a very easy job. I did it today it took about half an hour. The 2 wires back to the heater boxes is actually 1 wire which runs in separate metal tubes from the lever back to the heater boxes. If you look into the tunnel you will see the tubes. On the end of the lever there is a small hole. The wire runs from one heater box thru the tube then thru hole in the bottom of the lever and back down the other tube to the second heater box. Did that make sense hope you understood. Ah! Now I see exactly what you're talking about. Very useful, thanks. So I need to pull the broke one out. But the question is this: there are 2 thicker ends that go into the barrels on the heater valves. Would one of them fit through the little hole on the lever? Yes |
Synchromesh |
Apr 3 2015, 06:16 PM
[quote]
But the question is this: there are 2 thicker ends that go into the barrels on the heater valves. Would one of them fit through the little hole on the lever? [/quote] Yes [/quote] Thanks. Do I need to purchase any sort of grommets for this or just the wire and nothing else? |
Apr 3 2015, 06:22 PM
[quote name='Synchromesh' date='Apr 3 2015, 08:16 PM' post='2169447']
[quote] But the question is this: there are 2 thicker ends that go into the barrels on the heater valves. Would one of them fit through the little hole on the lever? [/quote] Yes [/quote] Thanks. Do I need to purchase any sort of grommets for this or just the wire and nothing else? [/quote] There are some rubber fittings that seal the end of the metal tube as it exits into the engine bay. 914rubber.com sells them. They are nice but not a must have. Do make sure to grease the cables. |
bdstone914 |
Apr 4 2015, 08:46 AM
Save your old one and compare it to the new one before installing. Just went through this on a 72. The bend on the new Porsche wire was wrong and was still too long on one end. I am told the 75 76 has a different length cable so it might work if you have the stock heater system. The new cable is not plastic coated like the old one. I think the longer end goes to the passenger side.
Apr 4 2015, 09:19 AM
Save your old one and compare it to the new one before installing. Just went through this on a 72. The bend on the new Porsche wire was wrong and was still too long on one end. I am told the 75 76 has a different length cable so it might work if you have the stock heater system. The new cable is not plastic coated like the old one. I think the longer end goes to the passenger side. I had to rebend my left side to be 2 inches longer than the right on my '71. |
914bub |
Apr 4 2015, 10:33 AM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
Save your old one and compare it to the new one before installing. Just went through this on a 72. The bend on the new Porsche wire was wrong and was still too long on one end. I am told the 75 76 has a different length cable so it might work if you have the stock heater system. The new cable is not plastic coated like the old one. I think the longer end goes to the passenger side. I had to rebend my left side to be 2 inches longer than the right on my '71. I was going to point this out yesterday but thought I was the only one who ran into this problem. I replaced my cable on my 72 about 6 months ago. I couldn't get the drivers side cable through the bend in the metal tube. I ended up bending the end of tha cable slightly as well as bending the end of the metal tube,(ever so slightly) to be a little more straight, to get the cable through. As for the length issue,I haven't hooked the cable up yet so I can't speak to length being correct or not. |
JawjaPorsche |
Apr 4 2015, 12:04 PM
My cable was bent wrong too. Used old cable to determine correct length. Long length goes passenger side.
Apr 4 2015, 12:33 PM
Eric Shea said it was 2" on his car.
Apr 4 2015, 04:02 PM
Synchromesh |
Apr 12 2015, 11:28 PM
So I started doing this today and ran into this problem, sort of. I was able to put them through the floor lever after some filing down of that little hole (rust) and they happily went into tubes and popped out properly. The problem is that they're too long both sides! Even if I get the ends all the way into the barrels when I pull the lever they still don't open the valves.
This led me to believe that I might have installed the heater valves wrong. My car didn't have them when I got it and I couldn't find a pic on the internet which showed them properly attached. Are the levers that attach to the wires on the valve supposed to be on top or bottom? Any other possibilities? I'm attaching a pic of what they look like now. Attached thumbnail(s) |
nihil44 |
Apr 13 2015, 03:13 AM
Member Group: Members Posts: 157 Joined: 28-January 12 From: Brisbane, Australia Member No.: 14,058 Region Association: None |
I also have similar issues with the orientation of the heater valves on the exchangers and the length of the cables.
I have tried putting the valves upside down and changed sides, flipped sides in the cables, but still can't get the ferrules on the end of the cables to line up with the barrel nuts on the valve levers. The cables seem to be too long or too short. I would really appreciate a photo of the correct installation of the heater valves. Also is there a difference in cable lenghts for various model years? |
Synchromesh |
Apr 13 2015, 09:25 PM
I also have similar issues with the orientation of the heater valves on the exchangers and the length of the cables. I have tried putting the valves upside down and changed sides, flipped sides in the cables, but still can't get the ferrules on the end of the cables to line up with the barrel nuts on the valve levers. The cables seem to be too long or too short. I would really appreciate a photo of the correct installation of the heater valves. Also is there a difference in cable lenghts for various model years? Anybody? Need to figure out how to solve this one! |
rjames |
Apr 13 2015, 11:02 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I also have similar issues with the orientation of the heater valves on the exchangers and the length of the cables. I have tried putting the valves upside down and changed sides, flipped sides in the cables, but still can't get the ferrules on the end of the cables to line up with the barrel nuts on the valve levers. The cables seem to be too long or too short. I would really appreciate a photo of the correct installation of the heater valves. Also is there a difference in cable lenghts for various model years? I believe so. I have a '75, and when I replaced my old flapper boxes with genuine Porsche NOS boxes the cables wouldn't reach on the passenger side. Sounds opposite to your problem though. |
Synchromesh |
Apr 14 2015, 01:44 PM
I believe so. I have a '75, and when I replaced my old flapper boxes with genuine Porsche NOS boxes the cables wouldn't reach on the passenger side. Sounds opposite to your problem though. Called Pelican. It turns out '71-74 have a different part number than '75-76. The latter has been discontinued so I'm stuck with the earlier cable. It appears I'll have to get creative with this thing here. But can anybody shoot me a pic of what this must look like anyway? |
bigkensteele |
Apr 14 2015, 04:33 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I believe so. I have a '75, and when I replaced my old flapper boxes with genuine Porsche NOS boxes the cables wouldn't reach on the passenger side. Sounds opposite to your problem though. Called Pelican. It turns out '71-74 have a different part number than '75-76. The latter has been discontinued so I'm stuck with the earlier cable. It appears I'll have to get creative with this thing here. But can anybody shoot me a pic of what this must look like anyway? I just used regular thick non-braided wire. The kind of stuff you would use for chicken-mesh. It works fine without the barrels on the end. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:16 PM |
