> Full Service Type 4 Machine Shop
Type 4
post Feb 14 2005, 10:25 PM
Type4parts is your source for Type4 Machine work.
John Edwards our Machinist has over Thirty years of experiance in the world of Automotive machine work.
John has been an Engine building Educator.
John is the author of
Sunnen's Complete Cylinder head and Engine Rebuilding Handbook.
This book is used worldwide in learning instituions to train Automotive machinists.
There isnt a machine work job that we cant do here at Type 4 parts.
NDT
Expert Visual Inspections
Magnetic Particle Inspection
Dye Penetrant Teesting
Pressure Testing
Vacuum Testing
Ultrasonic Thickness Testing
Surface Finish Measurement
Spring Pressure Testing
Precision Measurement to 0.0001
Head Work
Twin Plug Conversion
Heads opened up for 103-105 Cylinders
Precision Mulit-angle Seats
Centerless Valve Grinding
Oversized Valves
Giude and Valve Relocation
Resurfacing
Porting and Polishing
Flow Testing on Superflow
Case Work
Open up Case for 103-105 Cylinders
Alignboring
Machine Case for Type 1 Lifters
Lifter Boring and Sleeves
Deck Truing
Lifter Refacing
Cylinders
Boring for Larger Pistons
Sealing area Ridge for High Comprssion
Tops Trued
Custom Cylinder Sleeving for Reduced bore
Crankshaft
Bend Measurements
Grinding&Polishing
Chamfering
Oil Grooving
Counterweights
Keyway Reconstruction
Dowel Pin Installations
Connecting Rods
Resizing
Alignment
Balancing
Pin Bushing Conversions
Pin Oilers
Weight Reductions
Balancing
Crankshafts
Connecting Rods & Pistons
Flywheels
Crack Repairs
Dropped Seats and Combustion Chamber Repairs
Corrosion Damage
Cleaning
Biomatic Parts Washer
Pressure-Pt Sand Blaster
Thermal Cleaning System
Aqueous Pressure Washer
Welding
Oxy-Acetylene
AC/DC Arc
Heliarc (TIG)
MIG
Simtester
Engines Borken in On-The-Stand
An Inexpensive Alternative to Dyno Testing
Dynometer
1600Hp Computerized
Engine Dyno
Custom Running Cycles
Mill &Lathe Work
Genuine Bridgeport
Mill and Lathe
DRO Equipped
Fabrication
Intake Manifolds
Exhaust Headers
R&D Projects
If you can dream it up, Type 4 Parts can help bring your projects to completion.
- Lo-Fi Version Time is now: 19th May 2024 - 03:44 PM
