more rear camber required, I'm needing more camber |
returf |
Apr 4 2015, 02:00 PM
Member Group: Members Posts: 67 Joined: 15-August 12 From: New Zealand Member No.: 14,806 Region Association: Australia and New Zealand |
what's the most rear camber you can get witout screwing up the toe too much?
I tried adding a 20mm spacer under the front bolt of the adjustment plate, thereby pushing the rear upwards ( a bit ghetto i know) and this gives about - 2degrees camber. Are there any plates available to do this properly? |
brant |
Apr 4 2015, 06:21 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Positive camber?
Performance tires will like negative camber for contact patch We got around - 2.75 to -3.00 on the race car with stock pickups. But suspension and ride height play into the numbers. |
returf |
Apr 4 2015, 06:59 PM
Yes thanks Brant, more negative camber required. I'm running 275 x 18 slicks and I see that only the outside 15mm seems to be scuffed a little.
brant |
Apr 4 2015, 07:26 PM
What ride height? Spring rate? Radial slicks it sounds like. What brand?
returf |
Apr 4 2015, 11:51 PM
SirAndy |
Apr 5 2015, 02:02 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Your trailing arms (or tub) may be bent ... (IMG:style_emoticons/default/idea.gif)
Without any shims i can easily get -2.5 degrees camber on each side. But, the Goodyear slicks i'm running don't actually like that much camber. I run them at -0.5 degrees, any more and they'll eat up the insides of the tires. (IMG:style_emoticons/default/popcorn[1].gif) |
returf |
Apr 5 2015, 06:03 PM
Your trailing arms (or tub) may be bent ... (IMG:style_emoticons/default/idea.gif) Without any shims i can easily get -2.5 degrees camber on each side. But, the Goodyear slicks i'm running don't actually like that much camber. I run them at -0.5 degrees, any more and they'll eat up the insides of the tires. (IMG:style_emoticons/default/popcorn[1].gif) That is entirely possible, as they are lengthened by 90mm and moved out on the tube by 60mm. Ok then ,it looks like I'll have to make up new outside mounts. What rear toe are you using SirAndy? |
SirAndy |
Apr 5 2015, 07:45 PM
What rear toe are you using SirAndy? I measure the toe on the wheel rim, so that might not help you much. On my 15" wheels, i run -3mm toe. Meaning, compared to the alignment string, the difference between the rear distance to the wheel and the front distance to the wheel is 3mm. (IMG:style_emoticons/default/driving.gif) |
returf |
Apr 5 2015, 09:33 PM
What rear toe are you using SirAndy? I measure the toe on the wheel rim, so that might not help you much. On my 15" wheels, i run -3mm toe. Meaning, compared to the alignment string, the difference between the rear distance to the wheel and the front distance to the wheel is 3mm. (IMG:style_emoticons/default/driving.gif) Yes that's the way I do it as well. thanks for that Mike |
brant |
Apr 8 2015, 01:15 PM
the outside corner that you are seeing is what is likely not touching during cool down and drive into the pits
you really need a temp probe on the center and inside to compare numbers to the outside edge. also do this in the hot pits or tech with another body... the temp numbers change by the time you drive into the pits. I'm also wondering if your ride height is high enough to effect your numbers. Do you have to run a lot of ride height on account of the 18inch wheel diameter? what do the Michelin engineers recommend for tire temps? have a talk with the Michelin engineers before you change things |
Lo-Fi Version | Time is now: 20th May 2024 - 06:02 PM |
