Pertronix Ignitor III, any experience P-related or not? |
sportlicherFahrer |
Apr 6 2015, 06:15 PM
Nothing to see here. Group: Members Posts: 1,072 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
Was checking up on ignition upgrades from Pertronix again and saw that they offer the Ignitor III for our vacuum dizzies now. Supposed to work like a box style ignition without the box(multiple spark, rev limiter). Did a search here and didn't see anything for that model. Anybody used an Ignitor III and have any useful feedback on or off a Porsche? Not looking for opinions on whether or not Pertronix belongs in our cars or not, just on the functionality of the Ignitor III. With that said, I know this may start a (IMG:style_emoticons/default/stromberg.gif) storm..... (IMG:style_emoticons/default/stirthepot.gif)
ClayPerrine |
Dec 11 2019, 02:28 PM
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you are looking for a distributor that works well with carbs, get the stock distributor for a 74-74 1.8L L-Jet engine.
Then get this from Pertronix. https://pertronix.com/electronic-ignition-c...;model=914#auto Any of the three will work fine. The Ignitor I is what we have been running for years. Put it in, set the timing to 7.5 degrees at idle. Leave both vacuum connections disconnected. Then (IMG:style_emoticons/default/driving.gif) |
Gatornapper |
Dec 11 2019, 08:09 PM
Senior Member Group: Members Posts: 1,205 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Clay -
Thank you! What distributor would that be? The Pertronix was ordered Monday and will be here next Monday....... RE: The advance curve on the Dansk (which is now $67) - Pelican Parts does not have that information and sent me to the European supplier for the Dansk distributor. Every indication is that the Dansk is a clone of the 009 and thus shares the advance curve of the 009........ GN If you are looking for a distributor that works well with carbs, get the stock distributor for a 74-74 1.8L L-Jet engine. Then get this from Pertronix. https://pertronix.com/electronic-ignition-c...;model=914#auto Any of the three will work fine. The Ignitor I is what we have been running for years. Put it in, set the timing to 7.5 degrees at idle. Leave both vacuum connections disconnected. Then (IMG:style_emoticons/default/driving.gif) |
ClayPerrine |
Dec 11 2019, 09:54 PM
I don't know the part number, but you should be able to place a wanted to buy ad in the parts forum.
Clay Clay - Thank you! What distributor would that be? The Pertronix was ordered Monday and will be here next Monday....... RE: The advance curve on the Dansk (which is now $67) - Pelican Parts does not have that information and sent me to the European supplier for the Dansk distributor. Every indication is that the Dansk is a clone of the 009 and thus shares the advance curve of the 009........ GN If you are looking for a distributor that works well with carbs, get the stock distributor for a 74-74 1.8L L-Jet engine. Then get this from Pertronix. https://pertronix.com/electronic-ignition-c...;model=914#auto Any of the three will work fine. The Ignitor I is what we have been running for years. Put it in, set the timing to 7.5 degrees at idle. Leave both vacuum connections disconnected. Then (IMG:style_emoticons/default/driving.gif) |
Gatornapper |
Dec 12 2019, 07:39 AM
Clay -
Thanks. Talked to Pelican yesterday - they say the dizzy for the '74 1.8 is the Dansk, which is a clone of the 009........which I now have 2 of........ hmmmm............. GN I don't know the part number, but you should be able to place a wanted to buy ad in the parts forum. Clay Clay - Thank you! What distributor would that be? The Pertronix was ordered Monday and will be here next Monday....... RE: The advance curve on the Dansk (which is now $67) - Pelican Parts does not have that information and sent me to the European supplier for the Dansk distributor. Every indication is that the Dansk is a clone of the 009 and thus shares the advance curve of the 009........ GN If you are looking for a distributor that works well with carbs, get the stock distributor for a 74-74 1.8L L-Jet engine. Then get this from Pertronix. https://pertronix.com/electronic-ignition-c...;model=914#auto Any of the three will work fine. The Ignitor I is what we have been running for years. Put it in, set the timing to 7.5 degrees at idle. Leave both vacuum connections disconnected. Then (IMG:style_emoticons/default/driving.gif) |
ClayPerrine |
Dec 12 2019, 08:22 AM
Clay - Thanks. Talked to Pelican yesterday - they say the dizzy for the '74 1.8 is the Dansk, which is a clone of the 009........which I now have 2 of........ hmmmm............. GN Whomever you talked to at Pelican doesn't know 914s. There is a number on the 1.8L distributor that says 009, but it is NOT the same as the Bosch 009 distributor. The advance curve is completely different, and an L-Jet distributor has a vacuum advance. I will check my L-Jet parts stash this weekend. I am fairly sure I have an L-Jet distributor. Clay |
Gatornapper |
Dec 12 2019, 09:57 AM
Clay -
Do you see the '74 1.8 dizzy on either chart on Post 52 or 55? Also, what are the three digits prior to the 009? I hear they are definitive....... GN Clay - Thanks. Talked to Pelican yesterday - they say the dizzy for the '74 1.8 is the Dansk, which is a clone of the 009........which I now have 2 of........ hmmmm............. GN Whomever you talked to at Pelican doesn't know 914s. There is a number on the 1.8L distributor that says 009, but it is NOT the same as the Bosch 009 distributor. The advance curve is completely different, and an L-Jet distributor has a vacuum advance. I will check my L-Jet parts stash this weekend. I am fairly sure I have an L-Jet distributor. Clay |
Lo-Fi Version | Time is now: 29th April 2024 - 02:04 AM |
