7 Pages V « < 4 5 6 7 >
> Pertronix Ignitor III, any experience P-related or not?
Gatornapper
post Dec 13 2019, 07:04 PM
Post #101
Wow. And someone said the problem with the 178 009 was too much advance (22 deg. max.), and the 181 009 is perfect - but has 30+ deg. advance?
Now, if I can just find one of these 205 AA/181 009's.......
GN
QUOTE(rbzymek @ Dec 13 2019, 03:55 PM) *
Here is a graph of the curve base on the Pelican table data for the VW 022 905 205AA aka Bosch 231 181 009
ClayPerrine
post Dec 14 2019, 06:29 AM
Post #102
I can simplify this for you.
The factory 1.8L distributors have a vacuum advance on them.
The aftermarket "009" distributor does not.
Get a 1.8L distributor with a vacuum advance.
Gatornapper
post Dec 14 2019, 07:24 AM
Post #103
Clay -
I'd like to. Is this what one will cost? But I'm guessing the S is NOT the same as an AA.....
https://vwnos.com/022-905-205-s
GN
QUOTE(ClayPerrine @ Dec 14 2019, 07:29 AM) *
Gatornapper
post Dec 14 2019, 07:43 AM
Post #104
https://www.ebay.com/itm/Porsche-914-Bosch-...vEAAOSwGltazWC~
Should I grab it?
GN
ClayPerrine
post Dec 14 2019, 09:18 AM
Post #105
QUOTE(Gatornapper @ Dec 14 2019, 07:43 AM) *
It's a 1.8L distributor. The price is average. Up to you...
Gatornapper
post Dec 14 2019, 10:52 AM
Post #106
Clay -
Good ones seem to be hard to find, and I am happy with an average price -
Getting it....
Thanks for all the help.....
GN
QUOTE(ClayPerrine @ Dec 14 2019, 10:18 AM) *
rbzymek
post Dec 14 2019, 11:08 AM
Post #107
GN,
If you go with Pertronix I would suggest ignitor II instead of ignitor III. My ignitor III would drop sparks at idle. I did a warranty exchange and had the same result so I am getting a refund. My ignitor II is due to arrive in a day or so.
michael7810
post Dec 14 2019, 02:54 PM
Post #108
Sorry for the high Jack. Anyone have experience with Compufire? I’ve been working part time at a VW/Porsche repair shop for the past 6 months and we install a lot of compufires, at least 1 a week. So far I have not heard of any problems with them except occasionally the magnet ring (not sure what it’s called) contacts the rotor preventing it from going down far enough to get the cap on correctly. In those cases we grind a little off the bottom of the rotor with a belt sander and it’s good to go.
Gatornapper
post Dec 14 2019, 08:17 PM
Post #109
For the record: Just found a photo of an 0 231 168 005, and it is a
022 905 205P...
Still looking for the 205 that is an 050........
QUOTE(Gatornapper @ Dec 13 2019, 07:59 PM) *
NOW it makes sense!
Thank you!
On the Pelican list, they use the VW numbers.
Now - wondering what the Bosche numbers are for the following VW numbers, ending in:
205 D
205 E&F
205 J
Michael - no worries about a hijack - good info for all here re: the Compufire......
GN
QUOTE(rbzymek @ Dec 13 2019, 03:38 PM) *
GN,
That's the Bosch number 231 181 009. The VW part number is the the right of the VW logo (022 905 205 AA)
Gatornapper
post Dec 18 2019, 07:50 PM
Post #110
Clay -
Received my 1.8 dizzy with V.A. today. Will install it with the new Pertronix unit (1847A I think) as soon as engine is running on the old 009.....
GN
rhodyguy
post Dec 18 2019, 09:26 PM
Post #111
022 905 205 AB.
sportlicherFahrer
post Dec 18 2019, 09:52 PM
Post #112
Nothing to see here.
QUOTE(michael7810 @ Dec 14 2019, 12:54 PM) *
Compufire is another popular system, but I'm personally not a fan of it's reluctor wheel design. I've seen the wheel chafe through the wires a few times causing failures, and as stated the occasional fitment issue depending on manufacture of the rotor.
Gatornapper
post Dec 26 2019, 04:13 PM
Post #113
Pertronix owns Compufire. They told me.
QUOTE(sportlicherFahrer @ Dec 18 2019, 10:52 PM) *
Gatornapper
post Jan 14 2020, 10:35 AM
Post #114
Clay - Have this dizzy on my desk, not installed as engine still won't start.
Local 914 expert told me that vacuum advance dizzy will not work with carbs as there is not sufficient vacuum to activate the vacuum advance.
Did you know my 914 has IDF-44's? Your thoughts to his comment?
TIA,
GN
ClayPerrine
post Jan 14 2020, 12:22 PM
Post #115
With carbs, you don't need the vacuum advance. The mechanical advance in the distributor has the correct advance curve for the carbs. Even on the stock L-Jet injection, they didn't use the advance side of the vacuum can, just the retard side. And that only retards it a couple of degrees.
Clay
QUOTE(Gatornapper @ Jan 14 2020, 10:35 AM) *
TIA,
GN
Gatornapper
post Jan 14 2020, 12:56 PM
Post #116
Clay -
Thanks for the quick reply and good news. Looking forward to getting this dizzy on once the car is running.
Since the vacuum unit will not be used - is there any reason that it cannot be removed? Understanding that the open section in the side of the distributor case would have to be closed and sealed? I could easily do that with a piece of fabricated sheet metal.....
GN
QUOTE(ClayPerrine @ Jan 14 2020, 01:22 PM) *
Clay
TIA,
GN
Gatornapper
post Mar 3 2020, 07:30 AM
Post #117
Clay -
Put in this dizzy last week with Pertronix 1847V Ignitor and car ran perfectly!
For 10 min, until the Ignitor died........
Guess this post should be in this thread.........
http://www.914world.com/bbs2/index.php?s=&...t&p=2791024
GN
Tdskip
post Mar 3 2020, 08:36 AM
Post #118
Oh crud.
Not to give you a hard time but that is usually a fried unit. Could just be a bad one from the factory but...
Hope you get it sorted out and please do keep us posted.
Gatornapper
post Mar 3 2020, 11:27 AM
Post #119
Years in electronics myself - as Pertronix said, over-heating will cause label to turn yellow....no, it looked like new.....no signs of over-heating........
Will report on what happens. Meanwhile ordered a Hot Spark unit - always good to have a back-up anyway, and only $50.......
QUOTE(Tdskip @ Mar 3 2020, 09:36 AM) *
Oh crud.
Tdskip
post Mar 3 2020, 06:31 PM
Post #120
QUOTE(Gatornapper @ Mar 3 2020, 11:27 AM) *
Oh crud.
Weird, sounds like manufacturing defect.
- Lo-Fi Version Time is now: 6th June 2026 - 12:33 PM
