WTB engine tins or engine sheet metal, looking to buy many of the engine sheet metal |
carl07760 |
Apr 8 2015, 11:17 PM
Newbie Group: Members Posts: 3 Joined: 11-August 14 From: new jersey Member No.: 17,763 Region Association: North East States |
I am in need of the engine tins for my 914 4 cylinder. if i look in the haynes repair manual the names for the parts are as follows pg 23
- warm air duct left front & right front - warm air duct left rear - cylinder shroud (left) and the plate that is in front of the alternator cover plate alternator |
carl k |
Apr 9 2015, 09:10 AM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
I have the one of the warm air ducts. Haynes book of lies calls it "59 Warm air duct (right front)" but in the car it's on the left (drivers') side aft of the #1 cylinder. In good shape, $5 plus whatever shipping is. Carl K. I am in need of the engine tins for my 914 4 cylinder. if i look in the haynes repair manual the names for the parts are as follows pg 23 - warm air duct left front & right front - warm air duct left rear - cylinder shroud (left) and the plate that is in front of the alternator cover plate alternator |
type47 |
Apr 10 2015, 10:44 AM
You should specify engine size as spark plug locations are different between 1.7 and 1.8 heads and 2 L heads, that is, you cannot use 1.7 and 1.8 "cylinder shroud" on a 2 L head and vice versa. Since you're in NJ, you should try to hit the Hershey swap meet.
Lo-Fi Version | Time is now: 17th May 2024 - 09:23 PM |
