> Early to late fuel pump conversion, keeping early location - what else to carryover from early design?
jcschuf1
post Apr 9 2015, 10:17 PM
I am changing the fuel pump on my 73 1.7 from the stock pump (3 port)to the late model (2 port) pump. I have two questions I would appreciate feedback on. First, does the tank line from the pressure regulator need to be directed back to the pump inlet? It would make the routing of hoses infinitely easier if this could go directly back to tank. Also, directing it to the pump inlet seems unnecessary unless there would be an issue with starving pump? Secondly does anyone know of a fuel filter which could accept the 7/16" hose required for the pump inlet? Thanks in advance for any help.
JawjaPorsche
post Apr 10 2015, 06:05 AM
QUOTE(jcschuf1 @ Apr 10 2015, 12:17 AM) *
Just discard the Y-Connector. No return to fuel pump.
NAPA 3274 fuel filter.
See my set up in picture. I moved the pump to avoid vapor lock.
jcschuf1
post Apr 10 2015, 08:19 AM
Nice clean installation and many thanks for the help!
JawjaPorsche
post Apr 10 2015, 09:23 AM
You are welcome. Lots of wonderful people on this forum to help.
Dave_Darling
post Apr 10 2015, 10:00 AM
914 Idiot
Remember that you can make all sorts of adaptors from plumbing supplies if you need to.
--DD
914Sixer
post Apr 10 2015, 10:27 AM
The whole idea is to move the pump to the front to protect it from the elements and the heat exchangers.
boxsterfan
post Apr 10 2015, 10:56 AM
914's are kewl
I'm moving mine to the rear firewall like JawjaPorsche.
- Lo-Fi Version Time is now: 4th November 2025 - 09:26 AM
