Seat Belt Warning Relay, Need Help |
eric914 |
Feb 16 2005, 09:58 AM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
Does anyone have a circuit for what is going on inside the big brother box? Would it be possible to completely eliminate it with some modification?
The PO of my car cut some of the wires to the relay and I would like to do it right rather than trusting the hack job currently present. Thanks Attached image(s) |
bd1308 |
Feb 16 2005, 10:18 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
already done man. the two yellow wires are joined....thats all thats needed IMHO
Dave_Darling |
Feb 16 2005, 04:59 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Yup. If you want, you can solder them together and then shrink-wrap them to keep water/dirt out. Or use a crimp-on splice--but then you still want shrink-tubing to keep the water and dirt out.
The other wires don't do anything. Well, sort of... If you just cut them all off, other things in the car may not work correctly. To run a single wire to several different places, VW/Karmann would often run a wire to the one place, and crimp it and another wire into the connector on the end. The other wire would then run to another component. Sometimes yet another wire would be crimped in with this second wire in the next connector. Different components could be "daisy-chained" together this way without running separate wires to each. The key is, if there are two wires crimped together in any connectors, you can cut the wire and splice those two together. (Crimp or solder, your choice!) Remember, shrink-tubing will help keep the connection clean and dry. If there is only one wire going to a connector, you can cut it off and insulate the end (tape over it or some such). The two big fat yellow (or yellow/red) wires do need to be connected. --DD |
Lo-Fi Version | Time is now: 17th May 2024 - 04:13 PM |
