High Amp Alternator, bolt in application |
McMark |
Apr 13 2015, 04:03 PM
I needed a new alternator for the Turbo 1.7 car and with all of the upgrades I've done I thought I'd look around for a higher amperage unit to install. I know this has been done before, but I wanted something that was a more natural fit. And while I was looking, something with 'modern' technology would be nice.
I found a unit that looked promising and took the leap. It's a built to order, made in the USA unit. It features a built in regulator for a single wire installation, and it's 150 amps (also available in 240 amp! (IMG:style_emoticons/default/ohmy.gif) ). It finally arrived last week and holding it roughly in place nothing jumped out as a major problem, but there were a few tweaks to the housing. So a little trimming of the two mounting points, a bushing to reduce the pivot shaft diameter to 8mm, and drilling the top mount to 8mm it fits perfectly. Works just like an original unit, has MORE clearance than a stock unit although it weighs quite a bit more. (IMG:style_emoticons/default/wink.gif) I want to get this installed in my car before I make any promises, but this is looking like a REALLY easy upgrade. NO MORE VOLTAGE REGULATOR!!! (IMG:style_emoticons/default/aktion035.gif) Attached image(s) |
Elliot Cannon |
Apr 13 2015, 04:27 PM
So, what happens when the voltage regulator fails? How much heavier and what might be the cost?
Krieger |
Apr 13 2015, 04:33 PM
Advanced Member Group: Members Posts: 4,702 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Good work!
Geezer914 |
Apr 13 2015, 04:47 PM
Geezer914 Group: Members Posts: 1,382 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Pulley fan or rear cooling duck???
Kansas 914 |
Apr 13 2015, 05:27 PM
McMark |
Apr 13 2015, 05:43 PM
QUOTE Pulley fan or rear cooling duck??? The alternator is sold just as it's shown. I am probably going to merge a 914 alternator rear housing and the one that came on this unit. Should be able to make that work pretty easily. QUOTE So, what happens when the voltage regulator fails? How much heavier and what might be the cost? The VR may be replaceable, but I expect this new stuff to be much more robust. Which means, I expect to never have to touch this alternator/VR again ever. I didn't weigh it, but I would guess around double the weight. Cost TBD, but a rebuilt unit is under $100, and this will be at least triple that, plus... (IMG:style_emoticons/default/ph34r.gif) |
McMark |
Apr 13 2015, 11:51 PM
Looked and theres a fan inside. (IMG:style_emoticons/default/thumb3d.gif)
Elliot Cannon |
Apr 14 2015, 01:12 AM
euro911 |
Apr 14 2015, 02:17 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Looks good, Mark. Will the OEM alternator tin fit (or will it need to be modified a bit)?
Bartlett 914 |
Apr 14 2015, 06:45 AM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Looks like you are on a good find. Was this alternator designed for a specific rotation? I believe the air should exit to the front. If it has an internal fan, will it be able to do this? No all fans can be reversed |
McMark |
Apr 22 2015, 10:53 AM
QUOTE Was this alternator designed for a specific rotation? Just heard back that the alternator is the correct rotation for the Type 4. |
worn |
Apr 22 2015, 11:03 AM
can't remember Group: Members Posts: 3,145 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Elliot Cannon |
Apr 22 2015, 11:19 AM
Noticed that one too. Very common though. So much so that they named tape that way. I think even the HVAC people spell it that way now. (IMG:style_emoticons/default/laugh.gif) It's about time. (IMG:style_emoticons/default/av-943.gif) |
Kansas 914 |
Apr 22 2015, 01:32 PM
Bartlett 914 |
Apr 22 2015, 01:53 PM
euro911 |
Apr 22 2015, 06:36 PM
I think even the HVAC people spell it that way now. (IMG:style_emoticons/default/laugh.gif) It's about time. (IMG:style_emoticons/default/av-943.gif) One of my hobbies involves tropospheric ducting (IMG:style_emoticons/default/shades.gif) |
worn |
Apr 22 2015, 07:03 PM
There is warm air at the North Pole?
Also i can hardly wait Mark. Being decrepit and holding the alternator up there. Well, will the weight be an issue? |
McMark |
Apr 22 2015, 09:14 PM
I'll weigh it tomorrow... (IMG:style_emoticons/default/thumb3d.gif)
falcor75 |
May 15 2015, 01:03 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Since I'm going the efi route I think I'm going to need one of these.... (IMG:style_emoticons/default/blink.gif)
McMark |
May 15 2015, 07:56 PM
Efi doesn't need high amps. It's more hot big headlights, seat heaters, stereo, etc.
Lo-Fi Version | Time is now: 25th April 2024 - 11:57 AM |
