Sudden stalls |
Sudden stalls |
BfloRandy |
Apr 15 2015, 12:27 PM
Dimwit Extraordinaire Group: Members Posts: 66 Joined: 20-September 14 From: Buffalo, NY Member No.: 17,927 Region Association: North East States |
Good day, everyone. Having an issue that began in December, right before I covered the car for the winter. I have a '75 2.0 dual carbed (Weber 40). The car starts as it always has, that is, takes a try or two when it's warm out, and she's ready. Regardless of whether she's warmed up or still relatively cold, sometimes she just cuts out. This can happen at idle, or 3500 rpm. Doesn't seem to matter. When this happens, sometimes she starts right back up just by turning the key, other times, she needs a pump or two on the pedal, and yet other times, she just won't restart for what seems like forever. This is not an issue all the time. It may happen daily for a week, then not again for another week. I was just outside adjusting the carbs, and she died on me a half dozen times but restarted with just the key turned. The last time of course, she wouldn't restart. Probably will now that I've come inside... I don't know if this is a timing issue, a distributor issue, a fuel pump (and/or pump relay) issue. As you can tell, I'm a noob. Help?? More (helpful or not?) info: I went back out to give it another shot, same result. She didn't want to start. Cranks very well, brand new battery... On a whim, I popped the cap off of the distributor, everything inside looked fine. checked all the wires, they're pretty new and plugged in solidly. Got back in, and she fired right up, then died again almost immediately. Back to not wanting to start. Tried fiddling with the cap again, no help this time. I know I have a spare fuel filter lying around somewhere, gonna swap that in just for kicks. FWIW, when she is running, she goes just fine.
BfloRandy |
Apr 25 2015, 02:46 PM
Ok, gang. Here is an update:
Pulled the gas tank today. Sock was intact and pretty crud free, but I replaced it anyway. Replaced the fuel pump. Replaced fuel pump relay. She started up well as soon as the gas got to the engine. Ran for 5-10 minutes, then died. When cranking, I get a fair amount of whitish smoke from the exhaust, but doesn't catch. Hadn't noticed this before due to the wind direction. So, something is burning in there but it just doesn't catch enough to start, or it stumbles suddenly and dies when running. Incidentally, when it was running today, the engine sounded smooth, and the idle was right at about 975. I'm freaking baffled! (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 26th May 2024 - 08:59 AM |
