Taming this baby down, Been converting her back to street legal |
Blue6 |
Apr 16 2015, 10:03 PM
Senior Member Group: Members Posts: 1,026 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California |
Apr 17 2015, 05:11 AM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
No jack point either so someone has been there before. Looks like there is a piece of welded metal under the clamp.
rick 918-S |
Apr 17 2015, 06:40 AM
Hey nice rack! -Celette Group: Members Posts: 20,354 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
It should look like this.
Blue6 |
Apr 17 2015, 07:58 AM
Yep, the PO got rid of the jack points, and enlarged the holes through the braces in order to run the oil lines forward.
boxsterfan |
Apr 17 2015, 03:51 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
When I take my car down to bare metal, I plan on NOT having jackpoints. Never use them anyway and just an area for dirt and junk to get stuck up under the rockers.
damesandhotrods |
Apr 17 2015, 04:33 PM
Senior Member Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
You’re forgetting that Frisco is physically a very small city, surrounded on three sides by salt water…
Blue6 |
Apr 17 2015, 11:55 PM
No, that's why I was expecting rust ( at least coastal rust), but to be more accurate, the car was from Santa Cruz. All the same to us SoCal people. (IMG:style_emoticons/default/lol-2.gif)
Blue6 |
Dec 3 2016, 10:40 PM
It has been a really long time, but finally got to installing the inner long kit. With the help of Rob (914_Teener), were getting it done. Truth be told, it's really Rob with the expertise and doing the work. But I am assisting(handing him tools etc) (IMG:style_emoticons/default/biggrin.gif) ... Figured after cutting out the cage, this could restore some strength
speed metal army |
Dec 3 2016, 11:08 PM
Waiting for the rain to stop... Group: Members Posts: 1,058 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
I remember feeling like I was maybe wrecking my car while installing the long kit.. (IMG:style_emoticons/default/biggrin.gif)
When the stinky smoke cleared, I had a much stiffer 914. Worth it! Much stiffer chassis. |
porschetub |
Dec 4 2016, 12:16 AM
Advanced Member Group: Members Posts: 4,695 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Rand |
Dec 4 2016, 12:19 AM
When I take my car down to bare metal, I plan on NOT having jackpoints. Never use them anyway and just an area for dirt and junk to get stuck up under the rockers. and you get a flat tyre........ ...and then you use a scissor jack at one of many appropriate jacking points like any other car. (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Dec 4 2016, 08:54 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,455 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) I use the scissor jack that came with my Subaru donor car. It has a small gap in the middle that spans the flange on the bottom of the longs. (IMG:style_emoticons/default/beerchug.gif)
boxsterfan |
Dec 4 2016, 11:44 PM
A small-ish hydraulic jack can be stored in the car easily. There's easy room in the rear trunk or can be stored behind passenger seat.
It's also cheaper to pay for AAA then it is for body work to repair the jack plate areas. Attached image(s) |
Blue6 |
Feb 4 2017, 10:16 PM
Well, Rob (914 Teener) finished the inner long kit, and did a great job. Today, attempting to fit the eye candy ( pedal boards /dead pedal). Noticed my car doesn't have a clutch pedal. Must be one of them there automatics (IMG:style_emoticons/default/biggrin.gif)
horizontally-opposed |
Feb 4 2017, 10:28 PM
Advanced Member Group: Members Posts: 3,430 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
When I take my car down to bare metal, I plan on NOT having jackpoints. Never use them anyway and just an area for dirt and junk to get stuck up under the rockers. and you get a flat tyre........ ...and then you use a scissor jack at one of many appropriate jacking points like any other car. (IMG:style_emoticons/default/confused24.gif) Got rid of my jack points last time. Every time I took the rocker panels off, I watched all of the dirt and rocks and sand pour out. And this was quite often, making the amount of stuff that got up there depressing. Aluminum 944-style scissors jack now in front trunk. |
bdstone914 |
Feb 4 2017, 10:52 PM
bdstone914 Group: Members Posts: 4,496 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
When I take my car down to bare metal, I plan on NOT having jackpoints. Never use them anyway and just an area for dirt and junk to get stuck up under the rockers. and you get a flat tyre........ ...and then you use a scissor jack at one of many appropriate jacking points like any other car. (IMG:style_emoticons/default/confused24.gif) Got rid of my jack points last time. Every time I took the rocker panels off, I watched all of the dirt and rocks and sand pour out. And this was quite often, making the amount of stuff that got up there depressing. Aluminum 944-style scissors jack now in front trunk. Jack recievers strenghten the long at a flex point. Not good to remove them. |
StratPlayer |
Feb 5 2017, 04:00 PM
StratPlayer Group: Members Posts: 3,261 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
If you get rid of the jack points, are you going to fill in the holes on the rocker panels as well?
Blue6 |
Apr 14 2017, 09:25 PM
Thank god for these rallies, it makes me move the 914 to the front burner and get things done. Finished the hydraulic clutch install, finished the interior sound / heat proofing with seem sealer and insulation. I know several members are firmly opposed to permanent insulation, but he's a SoCal car now and won't see any wet weather.
Maddog's pedal board are very nice but needed a lot of massaging due to the new clutch pedal and lines. |
Blue6 |
Apr 14 2017, 09:28 PM
Blue6 |
Apr 14 2017, 09:39 PM
Lo-Fi Version | Time is now: 28th March 2024 - 11:06 PM |
