914/6 GT cable release kit GB LAST DAY TODAY !, These were $399, but the exchange rate is better |
Mikey914 |
Apr 20 2015, 05:36 PM
The rubber man Group: Members Posts: 12,625 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Would need to do at least 10 kits, I should be able to improve pricing. Just need at least 10 to make this happen.
VaccaRabite |
Apr 20 2015, 05:56 PM
En Garde! Group: Admin Posts: 13,407 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Pull to open, but then have to push down on them to close, right? Or is this an open and close solution?
Zach |
Harpo |
Apr 20 2015, 06:05 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I would be interested. Will it come with detailed instructions? The only instructions I have seen here are a little vague. I'm pretty sure you have to push down on the lights to close.
David |
Mikey914 |
Apr 20 2015, 06:59 PM
Mikey914 |
Apr 20 2015, 07:01 PM
I would be interested. Will it come with detailed instructions? The only instructions I have seen here are a little vague. I'm pretty sure you have to push down on the lights to close. David The manufacturer has not made any instructions available, but there is at least one documented install here somewhere. |
Larmo63 |
Apr 20 2015, 09:03 PM
I would be in if I knew how well they worked. Who wants to be the guinea pig?
Apr 20 2015, 09:13 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Chris folley posted an instal thread at one time. He also has a bolt in kit so you don't have to weld the mounts. It's an addition to Mikey's kit, not a substitute.
frankist |
Apr 20 2015, 09:26 PM
Newbie Group: Members Posts: 1 Joined: 6-May 07 From: socal. Member No.: 7,719 |
Count me in when this gets started. Ill be following this thread.
BuddyV |
Apr 20 2015, 09:35 PM
Robert Group: Members Posts: 552 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
B2524 |
Apr 20 2015, 09:57 PM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
Put me Down for one.
Kent |
ConeDodger |
Apr 21 2015, 12:30 AM
Apex killer! Group: Members Posts: 23,543 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I would be interested. Will it come with detailed instructions? The only instructions I have seen here are a little vague. I'm pretty sure you have to push down on the lights to close. David The manufacturer has not made any instructions available, but there is at least one documented install here somewhere. McMark installed mine. Maybe he'd have time to write something? (IMG:style_emoticons/default/smile.gif) |
ejm |
Apr 21 2015, 04:16 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,686 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
I've installed two kits. Assembly pictures and where to cut can be found on Armando's website. The kit leaves design and fabrication of the inside release mechanism to the installer.
nein14 |
Apr 21 2015, 01:52 PM
Senior Member Group: Members Posts: 838 Joined: 6-February 03 From: USA Member No.: 262 |
I have a set from Mittlemotor never installed in the original shipping envelope if anyone is interested PM me
Apr 21 2015, 01:58 PM
ChrisFoley |
Apr 21 2015, 02:14 PM
I am Tangerine Racing Group: Members Posts: 7,894 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I've installed two kits. Assembly pictures and where to cut can be found on Armando's website. The kit leaves design and fabrication of the inside release mechanism to the installer. |
shuie |
Apr 21 2015, 03:52 PM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
I'll take one. I also need the dash mount flange on the next page. Thanks for doing this.
68911l |
Apr 21 2015, 05:35 PM
Newbie Group: Members Posts: 11 Joined: 23-May 12 From: Norfolk, VA Member No.: 14,471 Region Association: None |
Put me down for 2 kits.
Harpo |
Apr 21 2015, 06:09 PM
It looks like the pull handle uses the same mounting base as the front trunk release. Does that mean that I have to use hood pins on my front trunk?
Thanks David |
kid914 |
Apr 21 2015, 06:19 PM
ALWAYS lead...NEVER follow!!!! Group: Members Posts: 2,534 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
stupid question here.......these are for the trunk??? (IMG:style_emoticons/default/blink.gif)
VaccaRabite |
Apr 21 2015, 06:41 PM
Headlights. It was race trim back in the way back. Cuts the weight of the headlight motors and electrics. The hood is pinned down, you dont need the release. Pull the release, and the lights come up. But to get them down you have to get out of the car and push them down. I have always wanted a set for my car, but don't know if I can justify it at this time. ;-/ Zach |
Lo-Fi Version | Time is now: 29th March 2024 - 05:56 AM |
