914/6 GT cable release kit GB LAST DAY TODAY !, These were $399, but the exchange rate is better |
Mikey914 |
Apr 20 2015, 05:36 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Would need to do at least 10 kits, I should be able to improve pricing. Just need at least 10 to make this happen.
Attached image(s) |
Harpo |
Apr 21 2015, 06:09 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
It looks like the pull handle uses the same mounting base as the front trunk release. Does that mean that I have to use hood pins on my front trunk?
Thanks David |
ChrisFoley |
Apr 21 2015, 08:27 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
It looks like the pull handle uses the same mounting base as the front trunk release. Does that mean that I have to use hood pins on my front trunk? Thanks David You don't have to give up the stock trunk release to use the GT headlight setup. The new pull handle can go on the dash. |
Lo-Fi Version | Time is now: 16th May 2024 - 09:29 AM |
