Christmas in April, Subaru 2.5 NA SOHC 2003 Impreza TS with 5MT Transmission |
R_u_dd |
Apr 22 2015, 06:58 AM
Member Group: Members Posts: 154 Joined: 3-March 14 From: Grants Pass, Oregon Member No.: 17,072 Region Association: Pacific Northwest |
After long deliberation and a lot of research on my Subaru Conversion, I received this engine transmission combination in the mail from Alberta, BC. It's a Naturally aspirated SOHC Subaru 2.5 litre out of an Impreza TS (2003) with 118K miles. I was able to get the transmission and ecu from the same car. The tranny is a 5mt with hydraulic clutch.
I tried the donor car approach on Copart and kept getting outbid for what I wanted to pay. In the end I went direct on ebay so I could get the exact engine year I wanted and I did not have a hulk sitting in the driveway for the neighbors to look at. I paid more than I wanted ($1,574 with shipping) to but in the end , you get what you pay for. Related Threads: Decision to Subarize or not to Subarize Engine Choices Poll on Best Engine Choices The plan is to change the head gaskets, check the condition of the clutch, and convert the transmission to front wheel drive. Any other suggestions on the engine? Anyone know it that's a push or pull style clutch? Looks like a push from the photo. Ian, I will be needing your help once you are up and running. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1429707522.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1429707522.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1429707522.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1429707522.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1429707522.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1429707522.6.jpg) |
JRust |
Apr 22 2015, 05:34 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Basically turned it into a pull with it looping around back. Then a bracket the cable bolts too. From there just through the clutch fork & uses the stock pedal cluster. It is a little on the stiff side. That can be changed with a little bigger throw on the arm. Hydrolic is a great way to go. I'd considered changing that out when I upgrade to my WRX turbo motor (IMG:style_emoticons/default/aktion035.gif)
Lo-Fi Version | Time is now: 20th May 2024 - 07:22 AM |
