Issues with Beetle CV joint failure? |
stownsen914 |
Apr 22 2015, 09:10 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Hi all,
With 914 CV joints being NLA now, I recently tried out Beetle CV joints when my old ones wore out on my 914/6 race car. I understand they are made by EMPI. I am using the same 914 axles I've used for years. After about 30 minutes of track time, one of the Beetle joints failed (the inner one on the right side of the car). Basically the joint seems to have been plunging too far inward and the lateral force seems to have just forced the joint apart. No broken parts are immediately apparent. The joint seems to have just fallen apart! I also noted that the inner races of the joints seem to be gouging the output flanges on the trans. This occurred on both sides fo the car. I had noticed some of this wear previously, but it seems to have accelerated significantly with the Beetle joints (especially considering only 30 minutes of use). See the pics below. It's hard to tell from the pics, but the wear spots are basically gouged into the flanges about a millimeter or so deep. I never had any failures or unusual wear with the 914 joints I used for years, so I am at a loss what happened here. Anyone have a similar issue with Beetle joints? I'm wondering if I should be trying Lobro or other joints, or a different setup entirely ... Attached image(s) |
Apr 22 2015, 10:53 AM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Yes, they over-extend and fail. There have been several threads about this, the first failure of this kind i saw was maybe 6 years ago on McMarks car.
However, there is a version that does work and i believe PMB sells them now. http://www.pmbperformance.com/catalog/item...868/9926705.htm (IMG:style_emoticons/default/beerchug.gif) |
malcolm2 |
Apr 22 2015, 11:06 AM
Advanced Member Group: Members Posts: 2,743 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Racer Chris from Tangerine Racing has also developed a joint.
http://www.tangerineracing.com/transmission.htm link to his Tranny page. Scroll down and you will see the joint or the whole axle for sale. I am sure you can call him or PMB and both will tell you the scoop. I went with the Tangerine unit. Installed 2 joints on one side. Couple thousand miles so far everything is A-OK. Make sure to get a bunch of the paper or cork gaskets and new schoor washers. While we are on the subject. I have been seeing some grease spatter from any and all joints. I have paper gaskets, is that something to live with? very small specs of grease have been flung on the under side of the trunk. |
malcolm2 |
Apr 22 2015, 11:24 AM
I knew I had a picture.... So actually the grease is coming from the "cap". The bolt side of the joint. This is on the OLD probably original CV joint. Don't have a shot of the CFR one.
Is this just a flaw we have to live with? You can see where it is on the starter in the background. |
stownsen914 |
Apr 22 2015, 12:14 PM
The cap gets distorted easily since it's thin metal, and can seep. I've fixed this in the past by removing the cap, caregully cleaning the perimter that mates with the CV joint, and sealing the surface between the cap and the CV with some RTV.
In the mean time, wrap some duct tape around the entire perimeter of the CV (IMG:style_emoticons/default/smile.gif) |
Jetsetsurfshop |
Apr 22 2015, 12:48 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
My drivers side made a nice grease line too. It seems that the gaskets doesn't compress on my car. I'll have to look at it closer.
(IMG:style_emoticons/default/driving.gif) |
mskala |
Apr 22 2015, 12:57 PM
The Tangerine ones have a step on the outside. This is sealed with an o-ring
which is hidden under the flange. This should stop grease from coming out there. |
ChrisFoley |
Apr 22 2015, 02:59 PM
I am Tangerine Racing Group: Members Posts: 7,911 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Yes, they over-extend and fail. Scott's problem doesn't appear to be related to that mode of failure. Note the amount of "damage" inside the output flange which indicates the axles are bottoming not hyperextending. Scott's failed CV is one of mine. After McMark's issue we carefully inspected the CVs we work with and couldn't find anything that would lead us to believe our assemblies would suffer the same result. What was written by Eric and/or Mark didn't just fit with our findings. I know of only one other on-track failure of the ones I sell, which was on a Lemons car in the mid-west. That one went 4 hours before the unloaded side came apart, probably by hyperextension. Matt Romanowski has lots of track time in his 3 liter car with our axles installed. In both failure cases there's no evidence of the cage being damaged. I have a test planned to hopefully gain further understanding of what happens. |
ThePaintedMan |
Apr 22 2015, 07:05 PM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
In both failure cases there's no evidence of the cage being damaged. I have a test planned to hopefully gain further understanding of what happens. Weird. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Randal |
Apr 22 2015, 10:54 PM
Hi all, With 914 CV joints being NLA now, I recently tried out Beetle CV joints when my old ones wore out on my 914/6 race car. I understand they are made by EMPI. I am using the same 914 axles I've used for years. After about 30 minutes of track time, one of the Beetle joints failed (the inner one on the right side of the car). Basically the joint seems to have been plunging too far inward and the lateral force seems to have just forced the joint apart. No broken parts are immediately apparent. The joint seems to have just fallen apart! I also noted that the inner races of the joints seem to be gouging the output flanges on the trans. This occurred on both sides fo the car. I had noticed some of this wear previously, but it seems to have accelerated significantly with the Beetle joints (especially considering only 30 minutes of use). See the pics below. It's hard to tell from the pics, but the wear spots are basically gouged into the flanges about a millimeter or so deep. I never had any failures or unusual wear with the 914 joints I used for years, so I am at a loss what happened here. Anyone have a similar issue with Beetle joints? I'm wondering if I should be trying Lobro or other joints, or a different setup entirely ... The CV set up that Chris sells is likely good. I had turbo 944 CV's on 222 and they never failed. The stock ones only lasted three 40 second runs. Lots of instructional information about installing 944 CV's on this site. |
stownsen914 |
Apr 23 2015, 11:01 AM
The CV set up that Chris sells is likely good. I had turbo 944 CV's on 222 and they never failed. The stock ones only lasted three 40 second runs. Lots of instructional information about installing 944 CV's on this site. Weird thing is thoiugh - I used the same set of stock 914 joints for many years on this car wtih no issue at all. The new one failed almost immediately. That would argue that the size/durability of the joint is not the issue. I'm going to take a closer look at the failed joint to see if I can figure out what caused it to fail. CV joints should not just pull apart ... |
Apr 23 2015, 11:11 AM
After McMark's issue we carefully inspected the CVs we work with and couldn't find anything that would lead us to believe our assemblies would suffer the same result. What was written by Eric and/or Mark didn't just fit with our findings. Eric's article is a bit misleading as it seems to put the blame on the inner cage. After McMarks failure, we went back and compared the new VW CVs with original 914 ones and noticed that on the VW CVs, the inner portion had significantly more side to side travel. So both extending or compressing them can result in a failure when force is applied at the same time. At that point, they basically just fall apart. (IMG:style_emoticons/default/popcorn[1].gif) |
Apr 23 2015, 11:12 AM
Weird thing is thoiugh - I used the same set of stock 914 joints for many years on this car wtih no issue at all. They are NOT stock 914 CVs, see my post above ... (IMG:style_emoticons/default/shades.gif) |
stownsen914 |
Apr 23 2015, 11:35 AM
Weird thing is thoiugh - I used the same set of stock 914 joints for many years on this car wtih no issue at all. They are NOT stock 914 CVs, see my post above ... (IMG:style_emoticons/default/shades.gif) By "same" I meant I used a single set of CVs for many years - not trying to imply that the Beetle CVs are the same as the old 914 ones. So are there differences between the Lobro Beetle CVs that are currently available vs. Empi or other brands? |
malcolm2 |
Apr 23 2015, 08:02 PM
Did I read that the balls are too small? Or at least have too much variability.
stownsen914 |
Apr 24 2015, 03:57 AM
ChrisFoley |
Apr 24 2015, 07:28 AM
... on the VW CVs, the inner portion had significantly more side to side travel. ... That is true. However, that shouldn't be enough to allow the joint to come apart unless there's a huge angular misalignment of the axle. One idea I'm looking more closely at is possibly installing teflon (or similar) buttons on the ends of the axle to prevent the shaft from travelling so far that a CV could allow a ball to come out of the track. |
Mugs914 |
Apr 24 2015, 11:18 AM
"Hey, yellow IS faster!" Group: Members Posts: 618 Joined: 22-July 05 From: Temple TEXAS Member No.: 4,452 Region Association: Southwest Region |
... on the VW CVs, the inner portion had significantly more side to side travel. ... That is true. However, that shouldn't be enough to allow the joint to come apart unless there's a huge angular misalignment of the axle. One idea I'm looking more closely at is possibly installing teflon (or similar) buttons on the ends of the axle to prevent the shaft from travelling so far that a CV could allow a ball to come out of the track. I've seen some CVs that have a stamped metal 'cap' that goes between the CV and the flange, presumably to limit the axle plunge and to retain grease. Taylor or someone may have one that will work. I'll be really interested to know why the Empis allow so much more lateral movement of the axle. Is there some difference in the actual design of the joint or is it just a difference in tolerances? (IMG:style_emoticons/default/confused24.gif) Mugs |
ChrisFoley |
Apr 24 2015, 01:18 PM
... I'll be really interested to know why the Empis allow so much more lateral movement of the axle. Is there some difference in the actual design of the joint or is it just a difference in tolerances? (IMG:style_emoticons/default/confused24.gif) Mugs I believe its due to longer slots in the cage. |
Matt Romanowski |
Apr 25 2015, 09:16 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
I've got years of time on Chris' CV joints with no trouble. I can't even say that we've repacked them.
If Chris tells me when we bought them, I can tell how many miles/hours are on them. |
Lo-Fi Version | Time is now: 30th April 2024 - 01:58 AM |
