Wanted 914-6 Wiper Assembly & Motor |
racerbvd |
Apr 25 2015, 11:24 AM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
Turns out that my wiper motor & parts vanished, so, now I need a replacement, any help would be appreciated.
914-628-019-10-OEM is the part number for the motor, it the rest the same as a 4?? Either way, looks like I need a replacement (IMG:style_emoticons/default/mad.gif) TIA |
914Sixer |
Apr 25 2015, 10:12 PM
914 Guru Group: Members Posts: 8,882 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Yes, you can take a tubing cutter and shorten the 911 rack and install the -4 wiper arm assembly. Remove the strap and drill a hole for the post mount. You then have a -6 rack.
911 wiper motor will need a harness made up to plug into column harness. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:50 AM |
