Compression Check Acceptable Numbers?, Compression Check |
91422.7 |
Apr 25 2015, 05:20 PM
Newbie Group: Members Posts: 36 Joined: 8-October 14 From: Eugene, Oregon Member No.: 17,991 Region Association: Upper MidWest |
I'm working on a friends car and we checked the compression with it cold. We retrieved the following readings: #1 cyl 70 lbs, #2-80 lbs., #3-80 lbs., #4-100 lbs., Engine has been running for about 6 months. Based on these readings what do you suggest? Is it ok to go ahead and get the engine running and drive it like it is or are you taking a chance of doing further damage? Run some diesel or ATF through the carbs and see if that would loosen the valves up some, then recheck Compression after a few hundred miles or is it time to tear it down and do a Valve job? Thanks for any suggestions.
euro911 |
Apr 25 2015, 09:02 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Don't be too quick to judge. The #s didn't real look good on my wife's 1.7 when we first tested it, but decided to let it be for the time being. One day I decided WTH and adjusted the valves - found #3 & 4 were tight (#3 was way too tight).
Interestingly, those were the low reading cylinders. The engine was really peppy after adjusting all the valves. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:21 PM |
