Compression Check Acceptable Numbers?, Compression Check |
91422.7 |
Apr 25 2015, 05:20 PM
Newbie Group: Members Posts: 36 Joined: 8-October 14 From: Eugene, Oregon Member No.: 17,991 Region Association: Upper MidWest |
I'm working on a friends car and we checked the compression with it cold. We retrieved the following readings: #1 cyl 70 lbs, #2-80 lbs., #3-80 lbs., #4-100 lbs., Engine has been running for about 6 months. Based on these readings what do you suggest? Is it ok to go ahead and get the engine running and drive it like it is or are you taking a chance of doing further damage? Run some diesel or ATF through the carbs and see if that would loosen the valves up some, then recheck Compression after a few hundred miles or is it time to tear it down and do a Valve job? Thanks for any suggestions.
VaccaRabite |
Apr 26 2015, 06:39 AM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Check the valves for sure.
Engine needs to be hot so everything is expanded. Throttle needs to be open so the cylinders are getting air. Valves need to be right so you are not leaking air out of a partially opened valve (valve too tight). After that, you can try a thick oil to bring up compression as you said. But at that point, you are ordering parts and saving money for the head rebuild. As DD said, just getting the engine adjusted and hot will bring your numbers up considerably. Zach |
Lo-Fi Version | Time is now: 15th May 2024 - 01:14 PM |
