Is the PRE fuel filter necessary? |
Bulldog9 |
Apr 26 2015, 07:25 AM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
I'm about ready to wrap up the under carriage of my project, and take it off the jack stands, and have a bit of a quandary as I put my fuel system supply together.
I've already replaced the fuel lines front and rear, new filter in the rear, and installed the new fuel tank. The last piece of the puzzle is to attach the fuel pump, but there is a REAL mismatch in the sizes of the nipple on the tank and fuel pump. The fuel outlet on the tank is about 12mm (1/2 inch) and the nipple on the CB performance low pressure fuel pump is about 7mm (1/4"). I made up a barbed fitting, but is now too long to fit comfortably and the fuel pump is pushed off to the side rather than center of the front suspension cross member. I know these tanks have a decent fuel screen/sock in the tank, and as this tank is super clean inside, am thinking about eliminating the pre filter. The barbed fitting is just about as long as the filter, and will fit perfectly. Can this pre (in pic) filter be eliminated and run the normal just before the carbs? Attached image(s) |
Bulldog9 |
Apr 26 2015, 07:15 PM
The issue is the size of the fuel outlet on the tank, it is almost 1/2" about 13mm. The nipples on the rest of the fuel system all to the carbs are the standard 7mm.
When I first saw the filter, I thought is was on the outlet of the pump, but I was surprised to see it is on the inlet side. The fitment issue is this is going on a 912E (basically a 76 911 with a 914 engine) |
Lo-Fi Version | Time is now: 15th May 2024 - 04:09 AM |
