COA Transmission number, Who has a Trans. number on their COA...Who doesn't |
914350 |
Apr 27 2015, 08:55 AM
Senior Member Group: Members Posts: 548 Joined: 21-April 14 From: Torrance Ca. Member No.: 17,275 Region Association: Southern California |
I received the COA for the 914-6 That Andy and I hauled back from Tennessee and it has the Transmission number listed on it (it is matching by the way (IMG:style_emoticons/default/biggrin.gif) ). Andy mentioned that he has seen many COA's that don't have the Trans. number on them so the question is... "Does your COA list a Transmission number or does it not?
...also What are your thoughts on why some due and many don't? The obvious answer being that the info. wasn't logged or has been lost but if you have any other idea as to why. Thanks. |
JeffBowlsby |
Apr 28 2015, 08:50 AM
914 Wiring Harnesses Group: Members Posts: 8,505 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The 914 Grasshopper had a COA with the tranny # on it. I simply told PCNA what it was and they put it on the COA. That was then.
Attached image(s) |
Johny Blackstain |
Apr 28 2015, 09:02 AM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
The 914 Grasshopper had a COA with the tranny # on it. I simply told PCNA what it was and they put it on the COA. That was then. GRASSHOPPER?! (IMG:style_emoticons/default/biggrin.gif) This goes with what I've said before regarding COA's... the more "homework" you do for them, the better the results are. It's absurd, since you're paying them to do the work, yet the results are garbage unless you do it for them. You end up doing the work & paying for it as well; Porsche should address this ASAP, or stop offering COA's. (IMG:style_emoticons/default/dry.gif) |
Gustl |
Apr 28 2015, 11:37 AM
914 enthusiast & historian Group: Members Posts: 11,503 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
This goes with what I've said before regarding COA's... the more "homework" you do for them, the better the results are. in Europe - well at least in Germany and Austria - it works a little different when you order the COA for your car, you have to tell them your VIN, engine number and tranny number - and only if the numbers you provided match the numbers recorded in their documents, you get them written down onto the COA they say this is to prevent "fake matching numbers cars" ... btw - my car has all matching numbers (including transmission), certified by Porsche (IMG:style_emoticons/default/aktion035.gif) |
914350 |
Apr 28 2015, 02:16 PM
This goes with what I've said before regarding COA's... the more "homework" you do for them, the better the results are. in Europe - well at least in Germany and Austria - it works a little different when you order the COA for your car, you have to tell them your VIN, engine number and tranny number - and only if the numbers you provided match the numbers recorded in their documents, you get them written down onto the COA they say this is to prevent "fake matching numbers cars" ... btw - my car has all matching numbers (including transmission), certified by Porsche (IMG:style_emoticons/default/aktion035.gif) That's exactly how it works with VW Bugs and Ghia's ect. when getting a "Birth Cert." they will only verify a number that you give them. This wasn't the case years back but again because people were alegedly (most likely) faking engine numbers, they changed their policy. |
Lo-Fi Version | Time is now: 15th May 2024 - 02:09 PM |
